    [MMM-NewsFeedTicker] scroll from left to right only?
    41 Posts 3 Posters 16.2k Views 4 Watching
      sdetweil @Cr4z33
      @Cr4z33 did u delete the old code?
      /*@-webkit-keyframes marquee {
        0% { left: 100%; }
        100% { left: -100%; }
      @-moz-keyframes marquee {
        0% { left: 100%; }
      @-ms-keyframes marquee {
        0% { left: 100%; }
      @-o-keyframes marquee {
        0% { left: 100%; }
      @keyframes marquee {
        0% { left: 100%; }
      notice the /* and */
      • Cr4z33C Offline
        Cr4z33
        @sdetweil of course I did. :)
          sdetweil @Cr4z33
          @Cr4z33 whoops. left out a change comment out the animations for other browsers
          .MMM-NewsFeedTicker .tickerbody {
            margin: 0 auto;
            width: 100%;
            padding-top: 5px;
            position: relative;
            white-space: nowrap;
            overflow: visible;
            /*-webkit-animation: marquee linear infinite;
            -moz-animation: marquee linear infinite;
            -ms-animation: marquee linear infinite;
            -o-animation: marquee linear infinite; */
          weird… on 2.11 it scrolls right to left
          on 2.12 is scrolls left to right
            i installed it again on my desktop system (from laptop), and it works as expected (on MM 2.12)
            • Cr4z33C Offline
              Cr4z33 @sdetweil
              @sdetweil nope mine ist still going back and forth.
                sdetweil @Cr4z33
                @Cr4z33 weird… I just re-installed MM and the module and changed the css and changed the newsfeed module config entry to MMM-NewsFeedTicker and started, left to right
                			module: "MMM-NewsFeedTicker",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                  from my dropbox , screen video capture
                  https://www.dropbox.com/s/vab6t9j0oa95zyw/Kazam_screencast_00000.mp4?dl=0
                  Cr4z33C 2 Replies Last reply Reply Quote 0
                  • Cr4z33C Offline
                    Cr4z33 @sdetweil
                    • Cr4z33C Offline
                      Cr4z33 @sdetweil
                        I don’t understand. the default, the text ( the beginning of the line of text) starts to appear on the right side of the screen and scrolls to the left ( last showing the end of the line of text)
                        my change, per your request, the end of the text appears on the left of the screen, and scrolls to the right ( last showing the beginning of the line of text)
                        this is for left to right language English. I don’t know if language setting changes the default marquee order
                          @Cr4z33 did u see my post above?
                          • Cr4z33C Offline
                            Cr4z33 @sdetweil
                            @sdetweil said in [MMM-NewsFeedTicker] scroll from left to right only?:
                            Yep saw also the video.
                            Dunno why my MM system ignores the CSS edit… :confounded_face:
                              sdetweil @Cr4z33
                              @Cr4z33 do you have a custom.css setting which would override the module?
                              • Cr4z33C Offline
                                Cr4z33 @sdetweil
                                @sdetweil indeed so that’s the reason then?? :anguished_face:
                                Update:
                                Nope it keeps going back and forth even without custom.css entry…
                                  sdetweil @Cr4z33
                                  @Cr4z33 did u delete custom.css, comment out or what?
                                  and restarted MM
                                  • Cr4z33C Offline
                                    Cr4z33 @sdetweil
                                    @sdetweil I deleted the file.
                                    Yes I restarted MM.
                                      sdetweil @Cr4z33
                                      @Cr4z33 that is
                                      ~/MagicMirror/css/custom.css
                                      right?
                                      and u edited the MMM-NewsFeedTicker.css in the MMM-NewsFeedTicker module folder to add my changes, yes?
                                      • Cr4z33C Offline
                                        Cr4z33 @sdetweil
                                        @Cr4z33 that is
                                        right?
                                        Correct. 👍🏽
                                          sdetweil @Cr4z33
                                          @Cr4z33 the module is still requesting to load the css directly, right? with the right name
                                              getStyles: function() {
                                                  return ["MMM-NewsFeedTicker.css"];
                                          one more thing, my module is running all default values, cause i changed the name of the default newsfeed module to this one… but did NOT set any config values…
                                          				feeds: [
                                          • Cr4z33C Offline
                                            Cr4z33 @sdetweil
                                            @sdetweil I tried using your defaults as well by getting the issue again.
                                            At this point could Debian 10 running (natively of course) on an Intel NUC be the problem?
