    Weather module works for current, shows 'loading' for forecast
    12 Posts 3 Posters 4.1k Views 3 Watching
      CliffordW @sdetweil
      @sdetweil This is the closest thing I can find reporting as an error. However, I commented out the forecast module, and this error is still reported.
      https://imgur.com/UrEI7tg
        sdetweil @CliffordW
        @CliffordW that’s because custom.css isn’t there by default.
          CliffordW @sdetweil
          @sdetweil Still not working.Any suggestions how I might troubleshoot this?
          I found this in the log:
          Failed to load resource: the server responded with a status of 401 (Unauthorized)
          A very long url to openweather is included.
          I tried using the ‘current’ apikey for forecast, the error disappeared, but still no display.
            matpi
            I have the exact same problem.
            @CliffordW Did you find a solution to solve the problem?
              sdetweil @matpi
              @matpi did u get new apikeys from openweather?
                matpi @sdetweil
                @sdetweil no I use this key for some time know 2-3 years at least. But the key works when it is placed in the current weather module. So I do not think the key is the issue.
                  matpi
                  found the problem :). id did not set:
                  weatherEndpoint: ‘/forecast’,
                  now it works.
                  thanks
                    sdetweil @matpi
                    @matpi awesome. can u mark this resolved? 3dots to the right, click the menu
