    Weather modules
    22 Posts 9 Posters 8.6k Views 9 Watching
    • BKeyportB Offline
      BKeyport Module Developer @ColinT
      @ColinT Not quite yet. They’re going apple only in a year or so.
        My darksky key is still working. My BMW series of weather modules uses darksky(still) and OpenWeather and Climacell keys. There’s also a Climacell Hourly. However, WeatherOrNot requires no api key at all.
        • W Offline
          wheresmygravy
          I just found MMM-WeatherOrNot after trying several others. I like it because you can set a background behind the module. My MagicMirror is not a mirror at all and uses random images behind all of my modules, so the contrast in needed.
          Is there a simple way to increase the size of the fonts? They are a little hard to read for my 81-yr old mother in law.
          Thank you.
            Mykle1 Project Sponsor Module Developer @wheresmygravy
            @wheresmygravy said in Weather modules:
            Unfortunately, font size is not an option with this module.
            Feedy88F 1 Reply Last reply Reply Quote 0
            • Feedy88F Offline
              Feedy88 @Mykle1
              @Mykle1 Woulnd’t it be possible via a custom css?
                Mykle1 Project Sponsor Module Developer @Feedy88
                @Feedy88 said in Weather modules:
                It would not. The module is inside of an iFrame and only those options available at the source can be modified. Font Size is not one of those options
                • Feedy88F Offline
                  Feedy88 @Mykle1
                  @Mykle1 Understood. Guess that is the part making it responsive as you change the size?
                    audun
                    This weather module works great.
                    https://github.com/martinkooij/MMM-MyWeather
                    It’s the same as the one from jclarke0000, but this uses weatherbit.io api instead.
                    • I Offline
                      icemanmw
                      Hi audun ,
                      thank you for the hint (that´s what i am looking for )
                      ,i tried to install but it is not running .
                      Just “loading” is displayed. Tried different config´s but no result. Is there a special thing to follow that it will run?
                        audun @icemanmw
                        @icemanmw
                        This config is working for me. Can you test.
                        Did you run npm install after git clone?
                        			module: 'MMM-MyWeather',
                        			position: 'top_left',
                        				fade: false,
                        				apikey: 'yourapikey', // private; don't share!
                        				lat: "59.613794", // Culemborg, NL ;)
                        				lon: "11.072405", // use the quotes!
                        				hourly: '1',
                        				coloricon: true,
                        				iconset: "colourful",
                        				fctext: '0',
                        				fcdaycount: "5",
                        				fcdaystart: "0",
                        				hourlyinterval: "3",
                        				hourlycount: "2",
                        				alerttime: 10000,
                        				alerttruncatestring: "english:",
                        				roundTmpDecs: 1,
                        				windunits: "kph",
                        				UseCardinals: 0,
                        				layout: "vertical",
                        				timeFormat: "HHmm",
