    Weather modules
    22 Posts 9 Posters 9.1k Views 9 Watching
    • Feedy88F Offline
      Feedy88 @BKeyport
      @BKeyport in my opinion it clearly is. Let’s see if some new modules pop up (openweather onecall API, climacell…)
      • BKeyportB Offline
        BKeyport Module Developer @ColinT
        @ColinT Not quite yet. They’re going apple only in a year or so.
          My darksky key is still working. My BMW series of weather modules uses darksky(still) and OpenWeather and Climacell keys. There’s also a Climacell Hourly. However, WeatherOrNot requires no api key at all.
          • W Offline
            wheresmygravy
            I just found MMM-WeatherOrNot after trying several others. I like it because you can set a background behind the module. My MagicMirror is not a mirror at all and uses random images behind all of my modules, so the contrast in needed.
            Is there a simple way to increase the size of the fonts? They are a little hard to read for my 81-yr old mother in law.
            Thank you.
              Mykle1 Project Sponsor Module Developer @wheresmygravy
              @wheresmygravy said in Weather modules:
              Unfortunately, font size is not an option with this module.
              Feedy88F 1 Reply Last reply Reply Quote 0
              • Feedy88F Offline
                Feedy88 @Mykle1
                @Mykle1 Woulnd’t it be possible via a custom css?
                  Mykle1 Project Sponsor Module Developer @Feedy88
                  @Feedy88 said in Weather modules:
                  It would not. The module is inside of an iFrame and only those options available at the source can be modified. Font Size is not one of those options
                  • Feedy88F Offline
                    Feedy88 @Mykle1
                    @Mykle1 Understood. Guess that is the part making it responsive as you change the size?
                      audun
                      This weather module works great.
                      https://github.com/martinkooij/MMM-MyWeather
                      It’s the same as the one from jclarke0000, but this uses weatherbit.io api instead.
                      • I Offline
                        icemanmw
                        Hi audun ,
                        thank you for the hint (that´s what i am looking for )
                        ,i tried to install but it is not running .
                        Just “loading” is displayed. Tried different config´s but no result. Is there a special thing to follow that it will run?
                          audun @icemanmw
                          @icemanmw
                          This config is working for me. Can you test.
                          Did you run npm install after git clone?
                          			module: 'MMM-MyWeather',
                          			position: 'top_left',
                          				fade: false,
                          				apikey: 'yourapikey', // private; don't share!
                          				lat: "59.613794", // Culemborg, NL ;)
                          				lon: "11.072405", // use the quotes!
                          				hourly: '1',
                          				coloricon: true,
                          				iconset: "colourful",
                          				fctext: '0',
                          				fcdaycount: "5",
                          				fcdaystart: "0",
                          				hourlyinterval: "3",
                          				hourlycount: "2",
                          				alerttime: 10000,
                          				alerttruncatestring: "english:",
                          				roundTmpDecs: 1,
                          				windunits: "kph",
                          				UseCardinals: 0,
                          				layout: "vertical",
                          				timeFormat: "HHmm",
