    Weather modules
    22 Posts 9 Posters 9.5k Views 9 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Feedy88
      @Feedy88 said in Weather modules:
      WeatherOrNot
      Thank you for the commendation. :thumbsup:
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @krisalexroberts
        @krisalexroberts
        Have you gone through all of these?
        https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules#weather
        StoffbeuteluweS 1 Reply Last reply
        • K
          krisalexroberts @Feedy88
          @Feedy88 WeatherOrNot is beautiful and fits the bill, thanks!
          Mykle1M 1 Reply Last reply
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @Mykle1
            @Mykle1 Hey Mykle, are there some news from the MMM-Lunartic api ?
            Greetings from Germany
            Mykle1M 2 Replies Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Stoffbeuteluwe
              @Stoffbeuteluwe said in Weather modules:
              I will check right now, Thanks for reminding me! :thumbsup:
              Greetings from New York City.
              • Mykle1M
                @krisalexroberts said in Weather modules:
                Fantastic! Thanks for your kind words.
                • Mykle1M
                  Still down. :-(
                  https://api.usno.navy.mil/imagery/moon.png?date=today&time=now
                  • BKeyportB
                    BKeyport Module Developer
                    Is WeatherOrNot the goto module now? the Darksky system’s locked me out I think. 😢😢
                    C Feedy88F 2 Replies Last reply
                      ColinT @BKeyport
                      @BKeyport Dark sky is now apple only ☹️
                      BKeyportB 1 Reply Last reply
                      • Feedy88F
                        Feedy88 @BKeyport
                        @BKeyport in my opinion it clearly is. Let’s see if some new modules pop up (openweather onecall API, climacell…)
                        • BKeyportB
                          BKeyport Module Developer @ColinT
                          @ColinT Not quite yet. They’re going apple only in a year or so.
                          • Mykle1M
                            My darksky key is still working. My BMW series of weather modules uses darksky(still) and OpenWeather and Climacell keys. There’s also a Climacell Hourly. However, WeatherOrNot requires no api key at all.
                            • W
                              wheresmygravy
                              I just found MMM-WeatherOrNot after trying several others. I like it because you can set a background behind the module. My MagicMirror is not a mirror at all and uses random images behind all of my modules, so the contrast in needed.
                              Is there a simple way to increase the size of the fonts? They are a little hard to read for my 81-yr old mother in law.
                              Thank you.
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @wheresmygravy
                                @wheresmygravy said in Weather modules:
                                Unfortunately, font size is not an option with this module.
                                Feedy88F 1 Reply Last reply
                                • Feedy88F
                                  Feedy88 @Mykle1
                                  @Mykle1 Woulnd’t it be possible via a custom css?
                                  • Mykle1M
                                    It would not. The module is inside of an iFrame and only those options available at the source can be modified. Font Size is not one of those options
                                    • Feedy88F
                                      Feedy88 @Mykle1
                                      @Mykle1 Understood. Guess that is the part making it responsive as you change the size?
                                      • A
                                        audun
                                        This weather module works great.
                                        https://github.com/martinkooij/MMM-MyWeather
                                        It’s the same as the one from jclarke0000, but this uses weatherbit.io api instead.
                                        • I
                                          icemanmw
                                          Hi audun ,
                                          thank you for the hint (that´s what i am looking for )
                                          ,i tried to install but it is not running .
                                          Just “loading” is displayed. Tried different config´s but no result. Is there a special thing to follow that it will run?
                                          A 1 Reply Last reply
                                          • A
                                            audun @icemanmw
                                            @icemanmw
                                            This config is working for me. Can you test.
                                            Did you run npm install after git clone?
                                            			module: 'MMM-MyWeather',
                                            			position: 'top_left',
                                            				fade: false,
                                            				apikey: 'yourapikey', // private; don't share!
                                            				lat: "59.613794", // Culemborg, NL ;)
                                            				lon: "11.072405", // use the quotes!
                                            				hourly: '1',
                                            				coloricon: true,
                                            				iconset: "colourful",
                                            				fctext: '0',
                                            				fcdaycount: "5",
                                            				fcdaystart: "0",
                                            				hourlyinterval: "3",
                                            				hourlycount: "2",
                                            				alerttime: 10000,
                                            				alerttruncatestring: "english:",
                                            				roundTmpDecs: 1,
                                            				windunits: "kph",
                                            				UseCardinals: 0,
                                            				layout: "vertical",
                                            				timeFormat: "HHmm",
