    Weather modules
    22 Posts 9 Posters 9.5k Views 9 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @krisalexroberts
      @krisalexroberts said in Weather modules:
      WeatherOrNot is beautiful and fits the bill, thanks!
      Fantastic! Thanks for your kind words.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Stoffbeuteluwe
        @Stoffbeuteluwe said in Weather modules:
        the MMM-Lunartic api
        Still down. :-(
        https://api.usno.navy.mil/imagery/moon.png?date=today&time=now
        • BKeyportB
          BKeyport Module Developer
          Is WeatherOrNot the goto module now? the Darksky system’s locked me out I think. 😢😢
          C Feedy88F 2 Replies Last reply
            ColinT @BKeyport
            @BKeyport Dark sky is now apple only ☹️
            BKeyportB 1 Reply Last reply
            • Feedy88F
              Feedy88 @BKeyport
              @BKeyport in my opinion it clearly is. Let’s see if some new modules pop up (openweather onecall API, climacell…)
              • BKeyportB
                BKeyport Module Developer @ColinT
                @ColinT Not quite yet. They’re going apple only in a year or so.
                • Mykle1M
                  My darksky key is still working. My BMW series of weather modules uses darksky(still) and OpenWeather and Climacell keys. There’s also a Climacell Hourly. However, WeatherOrNot requires no api key at all.
                  • W
                    wheresmygravy
                    I just found MMM-WeatherOrNot after trying several others. I like it because you can set a background behind the module. My MagicMirror is not a mirror at all and uses random images behind all of my modules, so the contrast in needed.
                    Is there a simple way to increase the size of the fonts? They are a little hard to read for my 81-yr old mother in law.
                    Thank you.
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @wheresmygravy
                      @wheresmygravy said in Weather modules:
                      Unfortunately, font size is not an option with this module.
                      Feedy88F 1 Reply Last reply
                      • Feedy88F
                        Feedy88 @Mykle1
                        @Mykle1 Woulnd’t it be possible via a custom css?
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Feedy88
                          @Feedy88 said in Weather modules:
                          It would not. The module is inside of an iFrame and only those options available at the source can be modified. Font Size is not one of those options
                          • Feedy88F
                            Feedy88 @Mykle1
                            @Mykle1 Understood. Guess that is the part making it responsive as you change the size?
                            • A
                              audun
                              This weather module works great.
                              https://github.com/martinkooij/MMM-MyWeather
                              It’s the same as the one from jclarke0000, but this uses weatherbit.io api instead.
                              • I
                                icemanmw
                                Hi audun ,
                                thank you for the hint (that´s what i am looking for )
                                ,i tried to install but it is not running .
                                Just “loading” is displayed. Tried different config´s but no result. Is there a special thing to follow that it will run?
                                A 1 Reply Last reply
                                • A
                                  audun @icemanmw
                                  @icemanmw
                                  This config is working for me. Can you test.
                                  Did you run npm install after git clone?
                                  			module: 'MMM-MyWeather',
                                  			position: 'top_left',
                                  				fade: false,
                                  				apikey: 'yourapikey', // private; don't share!
                                  				lat: "59.613794", // Culemborg, NL ;)
                                  				lon: "11.072405", // use the quotes!
                                  				hourly: '1',
                                  				coloricon: true,
                                  				iconset: "colourful",
                                  				fctext: '0',
                                  				fcdaycount: "5",
                                  				fcdaystart: "0",
                                  				hourlyinterval: "3",
                                  				hourlycount: "2",
                                  				alerttime: 10000,
                                  				alerttruncatestring: "english:",
                                  				roundTmpDecs: 1,
                                  				windunits: "kph",
                                  				UseCardinals: 0,
                                  				layout: "vertical",
                                  				timeFormat: "HHmm",
