Put RSS module in two places?
8 Posts 3 Posters 940 Views 3 Watching
  • T Offline
    tf2
    Is it possible to put the RSS module in two places on a MagicMirror implementation? I’d like it in the (default) lower third, but also in the top bar.
    When I try to add another RSS module with the position of top_bar, I get a config error. But I don’t know if that’s because I’ve mistyped something, or if it’s not possible to put the RSS module in two places at once.
    Thanks!
    S 1 Reply Last reply Aug 14, 2020, 7:40 PM Reply Quote 0
      sdetweil @tf2
      @tf2 can u show the config error?
      • T Offline
        thgmirror
        @tf2 I have two “newsfeed”-modules one over each other, both on the bottom-bar and it works
        But this is an exception, if you want to double any other module you have to copy the original folder, rename the folder and use this name to change the corresponding *.js in the new folder. Additionally, rename the Module.register name inside the js-file.
        You can verify your config.js here https://esprima.org/demo/validate.html for example.
        Hope that helps,
        Thomas
        T 1 Reply Last reply Aug 16, 2020, 12:17 AM Reply Quote 0
        • T Offline
          tf2 @thgmirror
          @thgmirror Just to make sure: Do you mean two instances of the module, or do you mean two separate RSS feeds in one module? I can do the latter, but for some reason the former isn’t working.
          If you’ve gotten two instances to work, then I have some kind of an error in my config file that doesn’t crash the mirror entirely.
          • T Offline
            thgmirror
            • T Offline
              thgmirror
              Hi @tf2, in my config.js, I have two newsfeed-instances:
              		module: "newsfeed",
              		position: "bottom_bar",
              			feeds: [
              					title: " 3 Podcasts",
              					url: "http://localhost:8080/modules/Podcast.rss2"
              			showSourceTitle: true,
              			showPublishDate: true,
              			broadcastNewsFeeds: true,
                          ignoreOldItems: true,
                          showDescription: true,
              			broadcastNewsUpdates: true,
                          wrapDescription: true
              and
              		module: "newsfeed",
              			feeds: [
              					title: "Tagesschau",
              					url: "http://www.tagesschau.de/xml/rss2"
              					title: "Spiegel Online",
              					url: "https://www.spiegel.de/schlagzeilen/index.rss"
              					title: "Radio Bonn Rhein-Sieg",
              					url: "https://www.radiobonn.de/thema/bonn-su-429.rss"
              which leads to this output:
              T 1 Reply Last reply Aug 16, 2020, 6:41 PM Reply Quote 0
              • T Offline
                tf2 @thgmirror
                @thgmirror Hey, thanks! Very helpful. Will try that out tonight.
                S 1 Reply Last reply Aug 16, 2020, 8:09 PM Reply Quote 0
                  sdetweil @tf2
                  @tf2 notice those were both configured to the same position, 1st in config it on top, next is lower, etc
                  they don’t HAVE to be in the same area
