    Video Playback Issue
    13 Posts 3 Posters 4.6k Views 3 Watching
      sdetweil @jimbydude
      @jimbydude mm uses a JavaScript browser called electron. very similar to chrome, but not the same. we are also a few releases behind, as raspberry pi is a limited platform too.
      you can use the chrome browser if u want, try from your pc connecting.
      there is not a lot of horsepower on the pi, compared to PC. pi 4 is better.
        sdetweil @jimbydude
        @jimbydude I added some support for split mode (server w chrome) in 2.10. but all the scripts were pushed out of the core mm in 2.11.
          A Former User
          maybe by enable OPENGL in raspi-config
          or try to use VLC for reading video
          Personnaly:
          • i have enabled OpenGL
          • I use VLC with one of my module for video playing and it’s good with RPI3B+ and RPI4
            jimbydude
            Thanks for the replies, looks like for out of box video niceness, need to wait until electron catches up.
            I don’t think the PI itself is struggling. As experiment I played in full screen on PI using Chrome, and at same time had full screen on two separate monitors connected to my local PC and they all played totally fine. So sounds like Electron is needing some TLC to catch up.
            I’ll mess with the OpenGL setting etc, and see how they compare.
            Cheers
              sdetweil @jimbydude
              @jimbydude and, you can use chrome as the browser instead of the built in one
                jimbydude @sdetweil
                @sdetweil Do you mean MM can be configured to use Chrome by default, or you mean just starting Chrome with URL (on the PI) using pm2 etc?
                  sdetweil @jimbydude
                  @jimbydude as I mentioned above you can configure it if, you get one file that was removed in 2.11
                  curl -sl https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                  chmod +x run-start.sh
                  edit package.json and replace the start stmt with this
                  "start", "./run-start.sh",
                  then edit config.js and set
                  serverOnly:'local",
                  this will launch the run-start.sh when u do npm start or pm2 start x
                  the script will check the setting of the serverOnly parm and if set to ‘local’,
                  will launch mm in server only and then launch chrome over it. from the outside you cannot tell the difference… (u can for video playback)
                  from config.js
                  			     //  local for armv6l processors, default
                  			     // false, default for all  NON-armv6l devices
                  			     // true, force serveronly mode, be```cause you want to.. no UI on this device
                  J S 2 Replies Last reply Reply Quote 2
                    jimbydude @sdetweil
                    @sdetweil very nice and thank you. I’ll try that out asap!
                    Cheers for helping :)
                      i created this script to help users with older pi0 / armv6l devices get up and running, because there is no electron version anymore, without having to figure all this out…
                      the project decided to support only pi3 and pi4.
                        jimbydude @sdetweil
                        @sdetweil I’m actually running this on Pi 4, so looks like your script is still necessary for anyone looking to play video.
                          sdetweil @jimbydude
                          @jimbydude i understand… however all the scripts were removed from the files distributed as part of the MM project… so i have to help users one at a time.
                          if you use the installation script from here, https://github.com/sdetweil/MagicMirror_scripts ,and u have one of the older devices I do this setup for you.
                            jimbydude
                            Just tried this out and works like a charm!
                            Rihanna now sounds and looks as smooth as intended.
                            Thanks for the quick and super helpful reply!!
