    pjestico/MMM-GoogleTrafficTimes Address Format?
    11 Posts 3 Posters 4.0k Views 3 Watching
      cmer3
      No errors, but I can’t get data to display. Google API key is right, so I am looking for format errors. Anything obvious?:
                  		module: 'MMM-GoogleTrafficTimes',
                  		position: 'top_right',
                      		key: 'AIzaSyAlettersandnumbersfYyA',
                      		origin: '39.408476,-76.545179',
                      		destination1: 'M Work:39.439013,-76.632005',
                      		destination2: 'C Work:39.399357,-76.593041',
                      		AvoidHighways: false,
                      		AvoidTolls: false,
        sdetweil @cmer3
        @cmer3 open the developers window ctrl-shift-i and select the console tab and scroll up to see any errors
        also, please use the code block.markers for config.js entries.
          sdetweil @cmer3
          @cmer3 I would guess origin values wrong. that is a string
          I think if it’s lat/long it needs to be that structure
          https://developers.google.com/maps/documentation/javascript/examples/map-latlng-literal
            cmer3
            Thanks, looks like my issues is setting up billing on the google account
              sdetweil @cmer3
              @cmer3 yeh, Google wants a good account payment method up front, even tho they will give u uncharged access for a while
              • F Offline
                Fonfon
                hi,
                Problem Nothing happens after installing the module …
                S F 2 Replies Last reply Reply Quote 0
                  sdetweil @Fonfon
                  @Fonfon what is your config for this module? did u setup the google account and credit card required? per the instructions?
                  • F Offline
                    Fonfon @Fonfon
                    • F Offline
                      Fonfon @sdetweil
                      @sdetweil said in pjestico/MMM-GoogleTrafficTimes Address Format?:
                      HI ,
                      Account payment is binding?
                        sdetweil @Fonfon
                        @Fonfon not sure what ‘is binding’ means, but if means ‘is required’, then yes.
                        Google requires an active functioning credit card, so IF/when you go over their credits they can charge you.
                        as compared to a free account, until it runs out and doesn’t work anymore.
                        they want it to keep working
                          @Fonfon open the developers window on the mirror, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors, usually red text.
                          you should see a message about the API usage
