    Raspberry pi 4 no hdmi output after a while
    3 Posts 3 Posters 1.7k Views 3 Watching
      Blauenfeldt
      So today after messing around with MMPM and GoogleAssistant, my monitor turned went blank, and the “no connection” appeared, and went to display the next active input.
      I use the HDMI input 1 with my Stationary PC and HDMI input with my Pi 4.
      Tried to switch back to my Pi, but got the “no connection”.
      I have tried switching HDMI inputs, but the hdmi from my Pi still show no connection. HDMI from my pc works fine.
      I then tried to connect via VNC, and had no problem. The “Screen configuration” still says 1920x1080 @ 60HZ, so no nothing weird there.
      I tried the tvservice -scommand and got this
      pi@MagicMirror:~ $ tvservice -s
      state 0xa [HDMI CUSTOM RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
      I don’t know what to do with that info, but hopes it helps. I have tried to google a little around, but didn’t find any definitive solution, that didn’t involve something I couldn’t see how it would help.
      I have seen some talk about the power supply. But I don’t think I have that issue, as I use an 3 amp power supply from TT Electronics.
      This problem also happens, if I use my Pi 4 on my 4k tv.
        sdetweil @Blauenfeldt
        @Blauenfeldt have u powered off your pi, and back on.
        I suspect you caused the HDMI port to be turned off. tvservice -o or the vgencmd
        I know there have been folks reporting that things that worked fine on pi3, won’t power back on on Pi4.
          [[global:former-user]]
          try to tunning /boot/config.txt in sudo mode.
          you can boost HDMI signal and force it at boot
          some command in terminal for RPI:
          • vcgencmd display_power
          results:
          1. display_power=0 -> screen off
          2. display_power=1 -> screen on
          • vcgencmd display_power 1
            -> force screen on
          • vcgencmd display_power 0
            -> force screen off
