    weatherforecast showing only two days.
    31 Posts 22 Posters 16.7k Views 21 Watching
      DavidCarreira @oemel09
      @oemel09 Thanks, your fix is working fine!
      • F
        FatTony123
        @oemel09… yep, just can confirm. This fix works like charm ;-)
        • W
          Wilfried @oemel09
          @oemel09 Perfect. Thanks for the workaround.
          • H
            Hindenberg @oemel09
            @oemel09 thx for your support. Different to many others, this fix doesn’t work for me. I’m running MM in a docker container and am not able to keep line 297 of weatherforecast.js edited. It always jumps back into its origin version:
            params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
            I tried in /mounts/modules/default/weatherforecast/ and also inside the container. I also set the container environment: MM_OVERRIDE_CSS: "false", but no way, after restarting the container, it is always showing the “old” values above
            Any hints?
            karsten13K 1 Reply Last reply
            • amarandA
              amarand @oemel09
              @oemel09
              Patch worked for me, thank you!
              • karsten13K
                karsten13 @Hindenberg
                @Hindenberg
                If you are using this setup https://gitlab.com/khassel/magicmirror#default-modules you need also set MM_OVERRIDE_DEFAULT_MODULES: "false"
                H 1 Reply Last reply
                • H
                  Hindenberg @karsten13
                  @karsten13 was pretty sure I did this. Works perfect, thanks a lot.
                  • kayakbabeK
                    kayakbabe @castletonroad
                    @castletonroad I have had the same eperience too.
                    • Z
                      zxjason
                        radioman
                        I have the same Problem
                        Thanks, your fix is working very good
                          MacRock
                          Hey guys,
                          may I’m to silly for that stuff but I’m not able to fix the 2 day problem.
                          If I change something in the weatherforecast.js and reboot the pi, every value is default again. I have changed a file named entrypoint.sh in the build directory. I set there both MM_OVERRIDE values to “false”.
                          Can please anybody help me to fix that?
                          • karsten13K
                            karsten13
                            If you are using this docker setup you have to set the MM_OVERRIDE values in the docker-compose.yml file as described in the link above (and not in entrypoint.sh).
                            The simple solution is to use the develop-image which contains already the changes you want to do. In this case you have to edit the docker-compose.yml file and replace the image from karsten13/magicmirror:latest to karsten13/magicmirror:develop.
                            In both cases after editing the docker-compose.yml file you have to restart the container. So navigate into the directory where the docker-compose.yml file is located and run docker-compose up -d.
                              banderjay
                              @oemel09 legend, i was going insane over this one
                              • E
                                ember1205
                                Can anyone explain why the Free API from OpenWeatherMap shows 7 Day Forecast but the discussion here (and what I actually see) is only being able to retrieve 5 days?
                                In looking at the documentation from the weather site, it appears that the URL should be constructed differently than how this weather module is building it out. Specifically, the URL should be something like:
                                https://api.openweathermap.org/data/2.5/onecall?lat={lat}&lon={lon}&exclude={part}&appid={API key}
                                But the URL is -actually- being built as:
                                https://api.openweathermap.org/data/2.5/forecast?id={id}&appid={API key}
                                It seems that the URL needs be different?
