    MM emulator?
    Scheduled Pinned Locked Moved Forum
    6 Posts 5 Posters 1.1k Views 4 Watching
    • Cr4z33C Offline
      Cr4z33 @leoliao1980
      @leoliao1980 either a VM with Debian or a dedicated (Debian) partition looks already fine to me.
        A Former User
          A Former User
          @hango with Windows based,it’s very very limited.
          complex module will not works (sample any module with voice [assistant])
          @Cr4z33 idea is really an alternative ;)
          Note: Raspbian is a debian version made for RPI
            sdetweil @leoliao1980
            @leoliao1980 install winscp or bitvise ssh client on your pc,
            then you can double click edit files on your pi, start and stop mm from the ssh window
            and use your browser to see the mm page ( w address:“0.0.0.0”, and ipWhitelist:[]
            set in the pi mm config.js
            it’s the best of both worlds
              @leoliao1980 also, the process is the same.
              you don’t edit IN mm, you edit the files used, then launch mm.
              you can do that in windows, as long as I don’t need access to any pi hardware.
              install process
              git clone like normal
              cd MagicMirror
              npm install
              cd …\fonts
              npm install
              cd …\vendor
              npm install
              cd …
              npm start
