npm start problem ELIFECYCLE
12 Posts 4 Posters 3.6k Views 4 Watching
  • E Offline
    emrah_asl
    Hi Guys,
    I’m trying to work MagicMirror on my Windows 10
    I did try all way , (cpm clear cache, npm install, eletcron install, deletenode_modeules directory, and re-install, delete package.json.lock etc)
    But when I call npm start server (or only npm start)
    It shows :
    magicmirror@2.12.0 start C:\Users\Emrah Aslan\Desktop\SmartWall\smartwall
    DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “server”
    ‘DISPLAY’ is not recognized as an internal or external command,
    operable program or batch file.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "server"
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.12.0 start script.
    npm ERR! C:\Users\Emrah Aslan\AppData\Roaming\npm-cache_logs\2020-09-05T00_05_52_349Z-debug.log
    How can I run this, on my browser ? I need your supervisor
    S 1 Reply Last reply Sep 5, 2020, 12:33 PM Reply Quote 0
      sdetweil @emrah_asl
      @emrah_asl finish install ( not supported on windows)
      cd MagicMirror
      cd vendor
      npm install
      cd ..\fonts
      npm install
      cd ..
      then restart mm
      E 1 Reply Last reply Sep 5, 2020, 1:08 PM Reply Quote 0
      • E Offline
        emrah_asl @sdetweil
        @sdetweil said in npm start problem ELIFECYCLE:
        cd MagicMirror
        cd vendor
        npm install
        cd …\fonts
        npm install
        cd …
        Sorry, the same Issue. I tried fix this, doe not sleep 25 hours. but no result ?
        I have also Internet Information server, is this something relaeted with this ?
        Please help me and we may make zoom meeting.
        Config Js:
        package.json
        localhost via browser
          we fixed this offline. he had to edit the DISPLAY stuff out of the start script in package.json
          I 1 Reply Last reply Jan 3, 2021, 7:23 PM Reply Quote 0
          • E Offline
            emrah_asl
            Yes, thank you very much for your small adjustment.
            • I Offline
              iNeusch @sdetweil
              @sdetweil Hey there, do you remember what the fix was exactly ? have the same issue… thanks !
              S 1 Reply Last reply Jan 3, 2021, 7:26 PM Reply Quote 0
                sdetweil @iNeusch
                @iNeusch edit the package.json, change the start line. remove the DISPLAY stuff…
                leaving
                ./node_modules…
                not near my computer, phone is terrible for cut & paste
                I 1 Reply Last reply Jan 3, 2021, 7:30 PM Reply Quote 0
                • I Offline
                  iNeusch @sdetweil
                  @sdetweil ok thanks :)
                  S 1 Reply Last reply Jan 3, 2021, 7:45 PM Reply Quote 0
                    sdetweil @iNeusch
                    @iNeusch change
                    to this
                    	"start": "./node_modules/.bin/electron js/electron.js",
                      bert269
                      I have exacthly the same problem Trying to install MM on Windows 10.
                      Followed the instructions, and got the DISPLAy errror. Followed the earlier instructions in this thread to clean it up. - no difference.
                      Followed these last instructions to remove the display, and new I get:
                      C:\Users\PC\MagicMirror>npm start
                      npm ERR! code EJSONPARSE
                      npm ERR! file C:\Users\PC\MagicMirror\package.json
                      npm ERR! JSON.parse Failed to parse json
                      npm ERR! JSON.parse Unexpected token . in JSON at position 172 while parsing near ‘…pts": {
                      npm ERR! JSON.parse “start”: ./node_modules/.bin/…’
                      npm ERR! JSON.parse Failed to parse package.json data.
                      npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                      Any help is appreciated, thanks.
                      S 1 Reply Last reply Oct 4, 2021, 4:36 PM Reply Quote 0
