    npm start problem ELIFECYCLE
    12 Posts 4 Posters 6.0k Views 4 Watching
    • E
      emrah_asl
      Hi Guys,
      I’m trying to work MagicMirror on my Windows 10
      I did try all way , (cpm clear cache, npm install, eletcron install, deletenode_modeules directory, and re-install, delete package.json.lock etc)
      But when I call npm start server (or only npm start)
      It shows :
      magicmirror@2.12.0 start C:\Users\Emrah Aslan\Desktop\SmartWall\smartwall
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “server”
      ‘DISPLAY’ is not recognized as an internal or external command,
      operable program or batch file.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "server"
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 start script.
      npm ERR! C:\Users\Emrah Aslan\AppData\Roaming\npm-cache_logs\2020-09-05T00_05_52_349Z-debug.log
      How can I run this, on my browser ? I need your supervisor
        sdetweil @emrah_asl
        @emrah_asl finish install ( not supported on windows)
        cd MagicMirror
        cd vendor
        npm install
        cd ..\fonts
        npm install
        cd ..
        then restart mm
        E 1 Reply Last reply
        • E
          emrah_asl @sdetweil
          @sdetweil said in npm start problem ELIFECYCLE:
          cd MagicMirror
          cd vendor
          npm install
          cd …\fonts
          npm install
          cd …
          Sorry, the same Issue. I tried fix this, doe not sleep 25 hours. but no result ?
          I have also Internet Information server, is this something relaeted with this ?
          Please help me and we may make zoom meeting.
          Config Js:
          package.json
          localhost via browser
            we fixed this offline. he had to edit the DISPLAY stuff out of the start script in package.json
            I 1 Reply Last reply
            • E
              emrah_asl
              Yes, thank you very much for your small adjustment.
              • I
                iNeusch @sdetweil
                @sdetweil Hey there, do you remember what the fix was exactly ? have the same issue… thanks !
                  sdetweil @iNeusch
                  @iNeusch edit the package.json, change the start line. remove the DISPLAY stuff…
                  leaving
                  ./node_modules…
                  not near my computer, phone is terrible for cut & paste
                  • I
                    iNeusch @sdetweil
                    @sdetweil ok thanks :)
                      sdetweil @iNeusch
                      @iNeusch change
                      to this
                      	"start": "./node_modules/.bin/electron js/electron.js",
                        bert269
                        I have exacthly the same problem Trying to install MM on Windows 10.
                        Followed the instructions, and got the DISPLAy errror. Followed the earlier instructions in this thread to clean it up. - no difference.
                        Followed these last instructions to remove the display, and new I get:
                        C:\Users\PC\MagicMirror>npm start
                        npm ERR! code EJSONPARSE
                        npm ERR! file C:\Users\PC\MagicMirror\package.json
                        npm ERR! JSON.parse Failed to parse json
                        npm ERR! JSON.parse Unexpected token . in JSON at position 172 while parsing near ‘…pts": {
                        npm ERR! JSON.parse “start”: ./node_modules/.bin/…’
                        npm ERR! JSON.parse Failed to parse package.json data.
                        npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                        Any help is appreciated, thanks.
                          sdetweil @bert269
                          @bert269 said in npm start problem ELIFECYCLE:
                          u have a typ0… quotes are required around things in json
                            bert269
                            Thank - that did the trick.
                            Appreciated!
