Solved magic mirror 2 config.js file
@elaineezhu but you were supposed to rename it…
@sdetweil this is the magic mirror folder that i renamed?
@elaineezhu well then , this explains the original problem…
the config in the ACTUAL ~/MagicMirror is not being changed, u were editing some OTHER magicmirror folder.
cause the $HOME/MagicMirror folder still exists
@sdetweil ohhhhh okay i get it. i’ve tried to edit the actual magicmirror folder (i think i might’ve had 2 or 3) and now it works! thank you so much for all your help :) i appreciate it!
All have to is copy the config.is.samples to your so you clear copy.
Just rename the file config.js and it will. Work if you muck it up you have a copy in you document to start over
Again just remember to make a copy again. -
@videogame95 said in [magic mirror 2 config.js file](/post/8157
All you have to do is copy the config.is.samples to your documents folder so you clear copy.
Just rename the file config.js and it will work . If you muck it up you have a copy in you documents
