    MMM-GoogleDriveSlideShow npm-install shows no progress
    7 Posts 2 Posters 1.4k Views 2 Watching
    • E Offline
      emrah_asl
      Hello , I would like to user this module, https://github.com/clegallic/MMM-GoogleDriveSlideShow
      It was fine for git clone operation, after that I tried to jump second step for “npm install” but it’s waiting 20 minutes, no progress.
      The screen was just like that :
      PS C:\Users\Emrah Aslan\D...\modules\MMM-GoogleDriveSlideShow> npm install
      [ .................] \ fetchMetadata: sill pacote range manifest for debug@4 fetched in 106ms
      BTW I created credential.json file and put under secret folder.
      I believe without that , I couldn’t run
      cd ~/MagicMirror/modules/MMM-GooglePhotos
      node generate_token.js
      PS C:\modules\MMM-GoogleDriveSlideShow> node generate-auth-token.js
      internal/modules/cjs/loader.js:968
        throw err;
      Error: Cannot find module 'googleapis'
      Require stack:
      - C:\modules\MMM-GoogleDriveSlideShow\generate-auth-token.js
      ?[90m    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)?[39m
      ?[90m    at Function.Module._load (internal/modules/cjs/loader.js:841:27)?[39m
      ?[90m    at Module.require (internal/modules/cjs/loader.js:1025:19)?[39m
      ?[90m    at require (internal/modules/cjs/helpers.js:72:18)?[39m
          at Object.<anonymous> (C:\Users\Emrah Aslan\Desktop\arneca\SmartWall\smartwall\modules\MMM-GoogleDriveSlideShow\generate-auth-token.js:3:18)
      ?[90m    at Module._compile (internal/modules/cjs/loader.js:1137:30)?[39m
      ?[90m    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)?[39m
      ?[90m    at Module.load (internal/modules/cjs/loader.js:985:32)?[39m
      ?[90m    at Function.Module._load (internal/modules/cjs/loader.js:878:14)?[39m
      ?[90m    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)?[39m {
        code: ?[32m'MODULE_NOT_FOUND'?[39m,
        requireStack: [
          ?[32m'C:\\Users\\Emrah Aslan\\Desktop\\arneca\\SmartWall\\smartwall\\modules\\MMM-GoogleDriveSlideShow\\generate-auth-token.js'?[39m
      Guys, Please help me on this.
        sdetweil @emrah_asl
        @emrah_asl did u do the npm install in the module folder like the install instructions say?
          @sdetweil sorry, missed problem above
          in the module folder erase package-lock.json if it exists and remove the node_modules folder, and then try npm install again
          • E Offline
            emrah_asl
            Hi @sdetweil I erased packahe-lock.jon file. Afterwards I typed npm-install still locked.
            PS C:\....\modules\MMM-GooglePhotos> npm install
            [ .................] \ fetchMetadata: sill pacote range manifest for p-limit@^2.0.0 fetched in 217ms
            Waiting here.
              sdetweil @emrah_asl
              @emrah_asl note I had a typo, package-lock.json
              no idea why the delay
              • E Offline
                emrah_asl
                I’m working with yarn instead of npm I will let you know result
                • E Offline
                  emrah_asl
                  I am not sure why it is not work, but it works with yarn install
                  thanks for your help
