    MMM-GoogleDriveSlideShow
    37 Posts 10 Posters 21.3k Views 11 Watching
      cgethycx @sdetweil
      @sdetweil thanks that helped somewhat. now MM2 loads but i just have a white box. Making progress though.
        clegallic
        You have to configure the module with the ID of the Google Drive folder (rootFolderId) where your photos are stored.
        You can check a complete answer here : https://github.com/clegallic/MMM-GoogleDriveSlideShow/issues/2#issuecomment-658843412
        Regards,
        Charles
          Jupter1
          first of all, I really like the ideaof the module. But I am currently stuck at creating the authentification with google and then the token. In step 7 of your readme, I have no “other” option to choose, so I chose “web application”. But in step 9 (using VNC to access the magic mirror), the authentification fails.
          Do you have any idea what is my mistake?
            clegallic
            Hi Jupter,
            I don’t think you made a mistake, and that the “type” choice at step 7 has any importance.
            Can you check that your credentials.json file looks like that ?
            {"installed":{"client_id":"[something].apps.googleusercontent.com","project_id":"[something]","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"[something]","redirect_uris":["urn:ietf:wg:oauth:2.0:oob","http://localhost"]}}
            Can you send me the detail of the error while trying to authenticate at step 10 ?
            Regards,
            Charles
            A 1 Reply Last reply
              Jupter1
              thank you for the overall looking of the JSON string. I checked it, it was not in this format. So I chose “Desktop” and now I got a credentials.json file that looks like your example. Then I tried again with a fresh module install from github. It still did not work.
              Here is the debug-log, that I get from npm. I hope you can help me with that.
              1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'token:generate' ]
              2 info using npm@3.10.10
              3 info using node@v6.14.2
              4 verbose run-script [ 'pretoken:generate', 'token:generate', 'posttoken:generate' ]
              5 info lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: mmm-googledriveslideshow@0.0.1
              6 silly lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: no script for pretoken:generate, continuing
              7 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: mmm-googledriveslideshow@0.0.1
              8 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: unsafe-perm in lifecycle true
              9 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              10 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: CWD: /home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow
              11 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Args: [ '-c', 'node generate-auth-token.js' ]
              12 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Returned: code: 1  signal: null
              13 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Failed to exec token:generate script
              14 verbose stack Error: mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
              14 verbose stack Exit status 1
              14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
              14 verbose stack     at emitTwo (events.js:106:13)
              14 verbose stack     at EventEmitter.emit (events.js:191:7)
              14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
              14 verbose stack     at ChildProcess.emit (events.js:191:7)
              14 verbose stack     at maybeClose (internal/child_process.js:920:16)
              14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
              15 verbose pkgid mmm-googledriveslideshow@0.0.1
              16 verbose cwd /home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow
              17 error Linux 4.19.66-v7+
              18 error argv "/usr/bin/node" "/usr/bin/npm" "run" "token:generate"
              19 error node v6.14.2
              20 error npm  v3.10.10
              21 error code ELIFECYCLE
              22 error mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
              22 error Exit status 1
              23 error Failed at the mmm-googledriveslideshow@0.0.1 token:generate script 'node generate-auth-token.js'.
              23 error Make sure you have the latest version of node.js and npm installed.
              23 error If you do, this is most likely a problem with the mmm-googledriveslideshow package,
              23 error not with npm itself.
              23 error Tell the author that this fails on your system:
              23 error     node generate-auth-token.js
              23 error You can get information on how to open an issue for this project with:
              23 error     npm bugs mmm-googledriveslideshow
              23 error Or if that isn't available, you can get their info via:
              23 error     npm owner ls mmm-googledriveslideshow
              23 error There is likely additional logging output above.
              24 verbose exit [ 1, true ]
                clegallic
                I can’t see any clue in your logs that can explain the issue.
                My Node version is slightly more recent than yours (v10.17.0 when yours is v6.14.2), it may be a reason.
                Can you try to run the npm run token:generatecommand through SSH ?
                Do you have the same error ?
                Regards,
                Charles
                J 1 Reply Last reply
                  Jupter1 @clegallic
                  @clegallic
                  Thank you for your support. I will try to update node and see if that fixes the problem and/or if running it via ssh changes anything when I am home again next week.
                    Jupter1
                    @clegallic
                    So I have tried to update node (v12.x) and voilà, now it works like a charm! Thank you for your support and this awsome module!
                      clegallic
                      I’m glad to hear that your problem is now resolved. Have fun with the module.
                      Regards,
                      Charles
                        chen31
                        First of all thank you, great module.
                        I have a question regard the picture size, there is a way to automatic resize the picture to the max WxH that I config in the module setup?
                          sdetweil @chen31
                          @chen31 does the module readme give u any info on re/sizing image display?
                          C 1 Reply Last reply
                            chen31 @sdetweil
                            No.
                            I have been over this a few times, except the max W and H, nothing.
                            The max W/H cut the photo in my case.
                            • E
                              emrah_asl
                              Hi, after deleted my photo from google drive , it still show even I change
                              refreshDriveDelayInSeconds: 5000,
                              refreshSlideShowIntervalInSeconds: 15,
                              How can I clear cache ? any idea
                              thank you for your helping.
                              • E
                                emrah_asl
                                I changed code like below to fix my problem @sdetweil in node_helper.js
                                getPhotos: async function() {
                                		// Check if need reload
                                		// Get cache if not already loaded and cache file exists (after a restart for example)
                                		if(!this.cache.created && this.cacheFileExists()){
                                			let needReload = !this.cache || (new Date().getTime() - this.cache.created) / 1000 > this.config.refreshDriveDelayInSeconds;
                                			// (re)create the cache if missing or expired
                                			if(needReload){
                                				this.log("No cache file, or expired, (re)creating it...");
                                				await this.createCache();
                                				this.cache.photos = await this.cache.photos.filter(photo=> !this.alreadySentPhotoIds.includes(photo.id));
                                			} else
                                			this.log("No memory cache, loading it from disk");
                                			await this.loadCache();
                                		} else this.createCache();
                                		return this.cache.photos;
                                  sdetweil @emrah_asl
                                  @emrah_asl you should submit that back to the author
                                  github fork the repo (top right button)
                                  download the fork
                                  change the forked code,
                                  git add/git commit/ git push
                                  then github create pull request to author
                                  then U have your saved copy on fork, and have contributed to improved module
                                  E 1 Reply Last reply
                                  • E
                                    emrah_asl @sdetweil
                                    @sdetweil Sure. I will this tomorrow, I’m just testing the changes.
                                    this time, client always sending request to google drive.
                                    I am not sure that my tricks are correct way.
                                      clegallic @chen31
                                      Hi @chen31
                                      The module is designed to adapt the display size of the image based on your maxWidth and maxHeight configuration (see there)
                                      If it does not works, perhaps the display is cut by another module above on your MagicMirror ?
                                      If not, can you share a screenshot to let me understand the problem.
                                      Regards,
                                      Charles
                                        clegallic @emrah_asl
                                        @emrah_asl
                                        @sdetweil is right, feel free to create a pull request.
                                        If you want to force cache reloading, you can also delete the .cache file in the module folder.
                                        The default cache lifetime is 24 hours (refreshDriveDelayInSeconds configuration parameter).
                                        Regards,
                                        Charles
                                          chen31 @clegallic
                                          @clegallic said in MMM-GoogleDriveSlideShow:
                                          Hi @chen31
                                          Regards,
                                          Charles
                                          Hi Charles,
                                          I went through this one more time and these are pictures that are portait.
                                          I saw that it’s in your TO DO list.
                                          Thank you.
                                          • E
                                            emrah_asl @clegallic
                                            @clegallic I think there is an issue here,
                                            I deleted one image 2 days ago, from google drive also I deleted content from cache file.
                                            But I see, it 'is still showing.
                                            When I add new ımage, it automatically detecting in 10 seconds to show this, but when I delete this it is not working same style.
                                            Can we optimize it at least one hour to refresh caches ?
