    MMM-GoogleDriveSlideShow
    37 Posts 10 Posters 21.3k Views 11 Watching
      clegallic
      MMM-GoogleDriveSlideShow allows you to display a slideshow of your photos stored in Google Drive.
      The MMM-GooglePhotos module allows to display photos stored in Google Photo, but as my photos are stored in Google Drive, I’ve created this module to create a slideshow of these photos on the Magic Mirror screen.
      The module is highly configurable :
      • Google Drive root folder
      • Theming
      • Number of folders to scan / photos to retrieve
      • Refresh interval of the slideshow and periodic scan of Google Drive
      • Integration with other modules notifications (PIR sensor for example to display next image)
      • Play mode (automatic, manual)
      Thanks to the MM team and all the community for their great work !
      Screenshots
      Download
      [card:clegallic/MMM-GoogleDriveSlideShow]
        sdetweil @clegallic
        @clegallic and if u get a suspend() call, u stop polling the server and stop attempting to display, right?
        C 1 Reply Last reply
          clegallic @sdetweil
          @sdetweil I wasn’t aware of the suspend()and resume() methods.
          I will update the module to implement these methods.
          Thank !
            clegallic
            It’s fixed now. Regards.
              cgethycx
              I am not having any luck installing this module. It is probably user error. I have MM2 up and running but when I paste the code and restart MM2 is tells ,e i need to create a config.js file.
              WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:56
              				rootFolderId: my id is here,
              SyntaxError: Invalid or unexpected token
                  at Module._compile (internal/modules/cjs/loader.js:722:23)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                  at Module.load (internal/modules/cjs/loader.js:645:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                  at Module.require (internal/modules/cjs/loader.js:685:19)
                  at require (internal/modules/cjs/helpers.js:16:16)
                  at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
                  at App.start (/home/pi/MagicMirror/js/app.js:202:3)
                  at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:126:7)
                  at Module._compile (internal/modules/cjs/loader.js:786:30)
              Do I need to add anything to the ID? I have tried adding quotes but that did not seem to work.
              thanks
                sdetweil @cgethycx
                @cgethycx said in MMM-GoogleDriveSlideShow:
                the rules for values in config.js
                whatever to the right of : if its numbers (1, or 21.25) or true/false it does not need quotes
                if it contains letters or spaces (this is a test, or 232130-1485i2jelnefkhwerh (apikey) it must be quoted,
                single or double doesn’t matter as long as start and end are the same.
                so, under the rules above
                this
                should be at least
                 rootFolderId: 'my id is here',
                read this helpful post
                https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1593192855243
                  cgethycx @sdetweil
                  @sdetweil thanks that helped somewhat. now MM2 loads but i just have a white box. Making progress though.
                    clegallic
                    You have to configure the module with the ID of the Google Drive folder (rootFolderId) where your photos are stored.
                    You can check a complete answer here : https://github.com/clegallic/MMM-GoogleDriveSlideShow/issues/2#issuecomment-658843412
                    Regards,
                    Charles
                      Jupter1
                      first of all, I really like the ideaof the module. But I am currently stuck at creating the authentification with google and then the token. In step 7 of your readme, I have no “other” option to choose, so I chose “web application”. But in step 9 (using VNC to access the magic mirror), the authentification fails.
                      Do you have any idea what is my mistake?
                        clegallic
                        Hi Jupter,
                        I don’t think you made a mistake, and that the “type” choice at step 7 has any importance.
                        Can you check that your credentials.json file looks like that ?
                        {"installed":{"client_id":"[something].apps.googleusercontent.com","project_id":"[something]","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"[something]","redirect_uris":["urn:ietf:wg:oauth:2.0:oob","http://localhost"]}}
                        Can you send me the detail of the error while trying to authenticate at step 10 ?
                        Regards,
                        Charles
                        A 1 Reply Last reply
                          Jupter1
                          thank you for the overall looking of the JSON string. I checked it, it was not in this format. So I chose “Desktop” and now I got a credentials.json file that looks like your example. Then I tried again with a fresh module install from github. It still did not work.
                          Here is the debug-log, that I get from npm. I hope you can help me with that.
                          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'token:generate' ]
                          2 info using npm@3.10.10
                          3 info using node@v6.14.2
                          4 verbose run-script [ 'pretoken:generate', 'token:generate', 'posttoken:generate' ]
                          5 info lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: mmm-googledriveslideshow@0.0.1
                          6 silly lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: no script for pretoken:generate, continuing
                          7 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: mmm-googledriveslideshow@0.0.1
                          8 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: unsafe-perm in lifecycle true
                          9 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                          10 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: CWD: /home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow
                          11 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Args: [ '-c', 'node generate-auth-token.js' ]
                          12 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Returned: code: 1  signal: null
                          13 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Failed to exec token:generate script
                          14 verbose stack Error: mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                          14 verbose stack Exit status 1
                          14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                          14 verbose stack     at emitTwo (events.js:106:13)
                          14 verbose stack     at EventEmitter.emit (events.js:191:7)
                          14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                          14 verbose stack     at ChildProcess.emit (events.js:191:7)
                          14 verbose stack     at maybeClose (internal/child_process.js:920:16)
                          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                          15 verbose pkgid mmm-googledriveslideshow@0.0.1
                          16 verbose cwd /home/pi/MagicMirror/modules/MMM-GoogleDriveSlideShow
                          17 error Linux 4.19.66-v7+
                          18 error argv "/usr/bin/node" "/usr/bin/npm" "run" "token:generate"
                          19 error node v6.14.2
                          20 error npm  v3.10.10
                          21 error code ELIFECYCLE
                          22 error mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                          22 error Exit status 1
                          23 error Failed at the mmm-googledriveslideshow@0.0.1 token:generate script 'node generate-auth-token.js'.
                          23 error Make sure you have the latest version of node.js and npm installed.
                          23 error If you do, this is most likely a problem with the mmm-googledriveslideshow package,
                          23 error not with npm itself.
                          23 error Tell the author that this fails on your system:
                          23 error     node generate-auth-token.js
                          23 error You can get information on how to open an issue for this project with:
                          23 error     npm bugs mmm-googledriveslideshow
                          23 error Or if that isn't available, you can get their info via:
                          23 error     npm owner ls mmm-googledriveslideshow
                          23 error There is likely additional logging output above.
                          24 verbose exit [ 1, true ]
                            clegallic
                            I can’t see any clue in your logs that can explain the issue.
                            My Node version is slightly more recent than yours (v10.17.0 when yours is v6.14.2), it may be a reason.
                            Can you try to run the npm run token:generatecommand through SSH ?
                            Do you have the same error ?
                            Regards,
                            Charles
                            J 1 Reply Last reply
                              Jupter1 @clegallic
                              @clegallic
                              Thank you for your support. I will try to update node and see if that fixes the problem and/or if running it via ssh changes anything when I am home again next week.
                                Jupter1
                                @clegallic
                                So I have tried to update node (v12.x) and voilà, now it works like a charm! Thank you for your support and this awsome module!
                                  clegallic
                                  I’m glad to hear that your problem is now resolved. Have fun with the module.
                                  Regards,
                                  Charles
                                    chen31
                                    First of all thank you, great module.
                                    I have a question regard the picture size, there is a way to automatic resize the picture to the max WxH that I config in the module setup?
                                      sdetweil @chen31
                                      @chen31 does the module readme give u any info on re/sizing image display?
                                        chen31 @sdetweil
                                        No.
                                        I have been over this a few times, except the max W and H, nothing.
                                        The max W/H cut the photo in my case.
                                        • E
                                          emrah_asl
                                          Hi, after deleted my photo from google drive , it still show even I change
                                          refreshDriveDelayInSeconds: 5000,
                                          refreshSlideShowIntervalInSeconds: 15,
                                          How can I clear cache ? any idea
                                          thank you for your helping.
                                          • E
                                            emrah_asl
                                            I changed code like below to fix my problem @sdetweil in node_helper.js
                                            getPhotos: async function() {
                                            		// Check if need reload
                                            		// Get cache if not already loaded and cache file exists (after a restart for example)
                                            		if(!this.cache.created && this.cacheFileExists()){
                                            			let needReload = !this.cache || (new Date().getTime() - this.cache.created) / 1000 > this.config.refreshDriveDelayInSeconds;
                                            			// (re)create the cache if missing or expired
                                            			if(needReload){
                                            				this.log("No cache file, or expired, (re)creating it...");
                                            				await this.createCache();
                                            				this.cache.photos = await this.cache.photos.filter(photo=> !this.alreadySentPhotoIds.includes(photo.id));
                                            			} else
                                            			this.log("No memory cache, loading it from disk");
                                            			await this.loadCache();
                                            		} else this.createCache();
                                            		return this.cache.photos;
