    MMM-GoogleDriveSlideShow
    37 Posts 10 Posters 20.9k Views 11 Watching
      Jupter1 @clegallic
      @clegallic
      Thank you for your support. I will try to update node and see if that fixes the problem and/or if running it via ssh changes anything when I am home again next week.
        Jupter1
        @clegallic
        So I have tried to update node (v12.x) and voilà, now it works like a charm! Thank you for your support and this awsome module!
          clegallic
          I’m glad to hear that your problem is now resolved. Have fun with the module.
          Regards,
          Charles
            chen31
            First of all thank you, great module.
            I have a question regard the picture size, there is a way to automatic resize the picture to the max WxH that I config in the module setup?
              sdetweil @chen31
              @chen31 does the module readme give u any info on re/sizing image display?
                chen31 @sdetweil
                No.
                I have been over this a few times, except the max W and H, nothing.
                The max W/H cut the photo in my case.
                • E
                  emrah_asl
                  Hi, after deleted my photo from google drive , it still show even I change
                  refreshDriveDelayInSeconds: 5000,
                  refreshSlideShowIntervalInSeconds: 15,
                  How can I clear cache ? any idea
                  thank you for your helping.
                  • E
                    emrah_asl
                    I changed code like below to fix my problem @sdetweil in node_helper.js
                    getPhotos: async function() {
                    		// Check if need reload
                    		// Get cache if not already loaded and cache file exists (after a restart for example)
                    		if(!this.cache.created && this.cacheFileExists()){
                    			let needReload = !this.cache || (new Date().getTime() - this.cache.created) / 1000 > this.config.refreshDriveDelayInSeconds;
                    			// (re)create the cache if missing or expired
                    			if(needReload){
                    				this.log("No cache file, or expired, (re)creating it...");
                    				await this.createCache();
                    				this.cache.photos = await this.cache.photos.filter(photo=> !this.alreadySentPhotoIds.includes(photo.id));
                    			} else
                    			this.log("No memory cache, loading it from disk");
                    			await this.loadCache();
                    		} else this.createCache();
                    		return this.cache.photos;
                      sdetweil @emrah_asl
                      @emrah_asl you should submit that back to the author
                      github fork the repo (top right button)
                      download the fork
                      change the forked code,
                      git add/git commit/ git push
                      then github create pull request to author
                      then U have your saved copy on fork, and have contributed to improved module
                      • E
                        emrah_asl @sdetweil
                        @sdetweil Sure. I will this tomorrow, I’m just testing the changes.
                        this time, client always sending request to google drive.
                        I am not sure that my tricks are correct way.
                          clegallic @chen31
                          Hi @chen31
                          The module is designed to adapt the display size of the image based on your maxWidth and maxHeight configuration (see there)
                          If it does not works, perhaps the display is cut by another module above on your MagicMirror ?
                          If not, can you share a screenshot to let me understand the problem.
                          Regards,
                          Charles
                            clegallic @emrah_asl
                            @emrah_asl
                            @sdetweil is right, feel free to create a pull request.
                            If you want to force cache reloading, you can also delete the .cache file in the module folder.
                            The default cache lifetime is 24 hours (refreshDriveDelayInSeconds configuration parameter).
                            Regards,
                            Charles
                              chen31 @clegallic
                              @clegallic said in MMM-GoogleDriveSlideShow:
                              Hi @chen31
                              Regards,
                              Charles
                              Hi Charles,
                              I went through this one more time and these are pictures that are portait.
                              I saw that it’s in your TO DO list.
                              Thank you.
                              • E
                                emrah_asl @clegallic
                                @clegallic I think there is an issue here,
                                I deleted one image 2 days ago, from google drive also I deleted content from cache file.
                                But I see, it 'is still showing.
                                When I add new ımage, it automatically detecting in 10 seconds to show this, but when I delete this it is not working same style.
                                Can we optimize it at least one hour to refresh caches ?
                                • A
                                  amanzimdwini @clegallic
                                  @clegallic - I am on a Rasp3A, but fully patched (npm 6.14.8, node 10.23.0, nodejs 10.23.0).
                                  As su, I fail npm run token:generate - with a
                                  Type Error: cannot read property '0' of undefined...
                                  (there is more). Upon inspection MY credentials.json file starts like
                                  {"web":{"client_id
                                  while your example begins
                                  {"installed":{"client_id
                                  (the rest looks similar to your example) Any idea what I did wrong? If I just replace my “web” with “installed”, I still fail.
                                  Thanks,
                                  K
                                  • W
                                    Wil
                                    I was trying to install this module but got an error at the npm run token:generate:
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-googleDriveSlideShow $ npm run token:generate
                                    > mmm-googledriveslideshow@0.0.1 token:generate /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                                    > node generate-auth-token.js
                                    /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/generate-auth-token.js:33
                                      const OAuth2Client = new google.auth.OAuth2(client_id, client_secret, redirect_uris[0]);
                                    TypeError: Cannot read property '0' of undefined
                                        at fs.readFile (/home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/generate-auth-token.js:33:86)
                                        at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the mmm-googledriveslideshow@0.0.1 token:generate script.
                                    npm ERR!     /home/pi/.npm/_logs/2021-01-19T20_03_53_720Z-debug.log
                                    and here is the associated log file:
                                    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'token:generate' ]
                                    2 info using npm@6.14.10
                                    3 info using node@v10.23.1
                                    4 verbose run-script [ 'pretoken:generate', 'token:generate', 'posttoken:generate' ]
                                    5 info lifecycle mmm-googledriveslideshow@0.0.1~pretoken:generate: mmm-googledriveslideshow@0.0.1
                                    6 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: mmm-googledriveslideshow@0.0.1
                                    7 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: unsafe-perm in lifecycle true
                                    8 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/modules/MMM-googleDriveSlideShow/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                    9 verbose lifecycle mmm-googledriveslideshow@0.0.1~token:generate: CWD: /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                                    10 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Args: [ '-c', 'node generate-auth-token.js' ]
                                    11 silly lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Returned: code: 1  signal: null
                                    12 info lifecycle mmm-googledriveslideshow@0.0.1~token:generate: Failed to exec token:generate script
                                    13 verbose stack Error: mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                                    13 verbose stack Exit status 1
                                    13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                    13 verbose stack     at EventEmitter.emit (events.js:198:13)
                                    13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                    13 verbose stack     at ChildProcess.emit (events.js:198:13)
                                    13 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                    14 verbose pkgid mmm-googledriveslideshow@0.0.1
                                    15 verbose cwd /home/pi/MagicMirror/modules/MMM-googleDriveSlideShow
                                    16 verbose Linux 5.4.83-v7+
                                    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "token:generate"
                                    18 verbose node v10.23.1
                                    19 verbose npm  v6.14.10
                                    20 error code ELIFECYCLE
                                    21 error errno 1
                                    22 error mmm-googledriveslideshow@0.0.1 token:generate: `node generate-auth-token.js`
                                    22 error Exit status 1
                                    23 error Failed at the mmm-googledriveslideshow@0.0.1 token:generate script.
                                    23 error This is probably not a problem with npm. There is likely additional logging output above.
                                    24 verbose exit [ 1, true ]
                                    Anyone have an idea how to solve this?
                                    • W
                                      Wil
                                      Ok I find the problem, my credential file was not good.
                                      I made a new one and the npm run token:generate worked.
                                      I write the config as mentioned, and start MM but no pictures appear.
                                      Is it long to load pictures?
                                        clegallic
                                        Hi Will,
                                        I’m glad to see that you have solved your token problem.
                                        The time it takes to load picture depends on the number of pictures you have. Note that only pictures meta-data are loaded at start. The picture binaries are loaded on demand when the slideshow starts.
                                        • if rootFolderId is not set, the module will retrieve the 100 first pictures found (maxResults)
                                        • if rootFolderId is set, the module will go through the 10 first folders (maxFolders) it founds. If you have a large amount of pictures, or if you specified a large value for maxFolders, it can take more times.
                                        If nothing is loaded or displayed, feel free to set debug to true and send me the logs.
                                        Regards,
                                        Charles
                                        • W
                                          Wil
                                          Hi clegallic,
                                          To test I only put 2 pictures, so it should be quite fast.
                                          Sorry for my ignoring but after setting debug: true in the config file, where do i see/find the logs?
                                            clegallic
                                            If your MM is deployed on a Raspberry Pi, you should find the logs in the /home/pi/.pm2 folder (pm2.log, logs/mm-error-0.log or logs/mm-out-0.log).
                                            Regards,
                                            Charles
