    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 16.7k Views 4 Watching
      Ameyalgudkar @sdetweil
      @sdetweil So, what I was trying to do is update my eeprom as I was getting the error at boot. and so I did the bootloader factory reset as the steps mentioned
      If your Raspberry Pi 4 will not boot, it is possible that the SPI EEPROM has become corrupted. To check, remove the SD card, disconnect the device from power, then reconnect it. If the green LED does not flash, this indicates that the EEPROM has become corrupted.
      Raspberry Pi Imager provides an easy way to fix this problem, by automatically preparing an SD card that will reprogram your Raspberry Pi 4’s EEPROM:
      Find an SD card that is empty, or does not contain any data you want to keep; it will be completely erased of all data during this process.
      Download Raspberry Pi Imager for your operating system from the list near the top of this page.
      Click “CHOOSE OS” and select “Misc utility images” then “Pi 4 EEPROM boot recovery”.
      Insert an SD card, click “CHOOSE SD CARD”, select the card you have inserted, then click “WRITE”.
      Once the SD card is ready, insert it into your Raspberry Pi 4 then connect the Raspberry Pi to power.
      Once complete, the green LED will blink rapidly in a steady pattern. Disconnect the device from power. Now you can remove the recovery SD card, insert your usual SD card, and resume using your Raspberry Pi.
      that fixed the issue with eeprom not being corrupted.
      But later checking the current eeprom I noticed, for some reason the default bootloader I have in Raspberry Pi’s eeprom has been set as such for every new boot I had to short the Global_EN with ground to boot the Pi.
      Even that being done it did not boot the new sd card’s no matter what. (So my guess right here is its cause of the makeshift power adaptor I am using which is converting 12v dc to 5v dc)
      At this point I’m starting to hate these newer RPI4’s already.
      Edit- so there was actually some issue with my SD cards not being flashed properly, now I have enabled the USB boot with the latest eeprom, and the PI boots normally. will get a good sd card reader.
        Ameyalgudkar @Guest
        @Bugsounet with your automated process it got installed within modules of magic mirror.
        • G Offline
          gelaw
          Was the error installing MMM-AwesomeAlexa solved? I am also stuck at the step “npm run prepublish”. (see below).
          I tried the fix to install libcblas, but my system shows that it is already installed.
          I am running a clean install of the latest Buster full release with a basic install of MagicMirror - no other add-on modules.
          root@raspberrypi:/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy# npm run prepublish
          > snowboy@1.3.1 prepublish /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
          > tsc --listFiles
          node_modules/@types/node/index.d.ts:20:1 - error TS1084: Invalid 'reference' directive syntax.
          20 /// <reference lib="es2015" />
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/typescript/lib/lib.es6.d.ts
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.ts
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/node-pre-gyp.d.ts
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/SnowboyDetectNative.d.ts
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/@types/node/base.d.ts
          /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/@types/node/index.d.ts
          /home/pi/MagicMirror/node_modules/@types/color-name/index.d.ts
          npm ERR! code ELIFECYCLE
          npm ERR! errno 2
          npm ERR! snowboy@1.3.1 prepublish: `tsc --listFiles`
          npm ERR! Exit status 2
          npm ERR!
          npm ERR! Failed at the snowboy@1.3.1 prepublish script.
          npm ERR!     /root/.npm/_logs/2020-09-13T14_34_37_010Z-debug.log
            A Former User @Ameyalgudkar
            @Ameyalgudkar sure that’s why I do my own … because to complex to build with original repo
            I fork it and correct source file, upgraded some library.
            Add some personal change for simply configuration…
            But i never tested it in this module … maybe there is a few change to do … i don’t know really
            I don’t use Alexa ':(
              Ameyalgudkar @gelaw
              @gelaw no it didn’t. still trying to figure somehow to install Snowboy. just the npm install method is not executing properly. I need the help of dev if I could. but looks like he hasn’t touched his post for a while.
                sdetweil @Ameyalgudkar
                @Ameyalgudkar did u run my script? you keep going thru the steps even if there are errors…
                  @sdetweil yes I tried, but snowboy not getting installed. here is the errors
                  if that would be helpful for you to understand what is actually happening. sorry for the file being very long and tiring.
                    A Former User
                    install nan wih npm
                      @Ameyalgudkar no you did NOT use my script, OR follow the instructions… the instructions explicitly tell you to install nan
                      https://awesome-alexa.js.org/#/installation
                      my script, which is same as the instructions for this module, plus the step to add the one dependency
                      over and over we asked if u followed the instructions… but u have not…
                      #!/bin/bash
                      cd ~/MagicMirror/modules # Navigate to module folder
                      if [  ! -e   ~/MagicMirror/modules/MMM-awesome-alexa ]; then
                         git clone https://github.com/dolanmiu/MMM-awesome-alexa.git # Clone this repository
                       fi
                       cd MMM-awesome-alexa # go into the module directory
                       v=$(apt -qq list libatlas-base-dev 2>/dev/null)
                       if [ "$v". == "." ]; then
                         sudo apt-get install libatlas-base-dev
                       fi
                       npm install --only=prod # Install depdendencies
                       cd node_modules
                       rm -rf snowboy # Remove the installed snowboy
                       git clone https://github.com/Kitt-AI/snowboy.git # Manually get snowboy from git
                       cd snowboy # Go into the /snowboy directory
                       rm -rf node_modules
                       npm install nan --save # Make sure you install this in the /snowboy directory        /< --------------------------------------------
                       npm install node-pre-gyp@0.12.0 --save # Make sure you install this in the /snowboy directory
                       npm install # Make sure you install in the /snowboy directory
                       npm run prepublish # Make sure you run this in the /snowboy directory
                       npm install --save-dev electron-rebuild # Make sure you install this in the /snowboy directory
                       npm install nan # Make sure you install this in the /snowboy directory
                       ./node_modules/.bin/electron-rebuild # Build snowboy to your device specifications, in the /snowboy directory
                        @sdetweil now I really dont know what else I have to follow, you can see each and every step I did, I literally copy pasted all the commands as they are. in the same order and directories, I havent included the first few steps mentioned as they get executed every time. I have posted every step which has got errors.
                          @Ameyalgudkar ignore the errors and keep going… it WILL FAIL til the last step…
                          which is why I offered the script to do it for you
                            @sdetweil how should I run the script? I tried the bash c but that didnt worked so did everything from script manually.
                            I will run the script exactly as you say and then will show you result if thats ok. also please let me know in which directory should I run the script.
                              @Ameyalgudkar
                              cut and paste this line into a terminal window
                              bash -c  "$(curl -sL https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0)"
                                @Ameyalgudkar said in MMM Awesome Alexa installing snowboy.:
                                I tried the bash c
                                looks like you forgot the - in front of c
                                bash -c do-install.sh
                                and didn’t mark it executable
                                chmod +x do-install.sh
                                (if u already downloaded the file)
                                • G Offline
                                  gelaw
                                  @sdetweil Thank you! I finally found my mistake. Yes it does work when your script is followed exactly.
                                    sdetweil @gelaw
                                    @gelaw i just made a script out of the steps provided by the author, with one fix for a dependency.
                                      @sdetweil Okay, would gladly like to tell that this did get the errors but it worked even with them. I didn’t knew until now that its fine to get those errors as no one mentions them anywhere in the scripts. Now the one thing is that the alexa only listens once and then stops listening to hotword. My mic is working and I have checked that. Speakers are working, I read somewhere about the electron and Chrome issue not sure if that would be the reason. But if that is then I will try, if that doesn’t work ill ask.
                                      Thank you for the help and support
                                      • 2 / 3
