    MMM-GABackgound -- Allow Change GoogleAssistant Background
    11 Posts 2 Posters 2.7k Views 2 Watching
      A Former User
      MMM-GABackground
      This module is an extension for MMM-GoogleAssistant.
      It allows to change the default Google Assistant background to your own or with animated gifs for each status of the assistant
      Needed: MMM-GoogleAssistant
      More informations on my Repository
        A Former User
        Ok, sorry, I have do some mismake on ReadMe and on recipe of with-Background.js
        it’s corrected :)
          banbutcher
          where does the new assistant show up? in the top left corner where the 4 google dots are?
          ive added the recipe with-BackgroundStatus.js to the GA List and theres been no changes?
          thanks
            A Former User
            The Background of the screen like that :
            • Before : (without GAB)
            • After: (With GAB)
              banbutcher
              Hmmm, doesn’t seem to be working! should it just show up?
              i did not edit the with-BackgroundStatus file as i like the jarvis, i dont think im missing any steps!?
              thanks again
                A Former User
                1. do you have the default GA background without GBA recipe ?
                  • blackscreen ?
                    -> you use MMM-pages, so configure it correctly !
                  • You have the GA default background perfect !
                2. If you have default background without GBA recipe :
                  -> place your GAB recipe file in queue any recipes
                3. tell me result
                  banbutcher
                  Hmmm…
                  without recipe i have black background. with recipe in queue, still black background.
                  i didnt have GAB in MMM-pages and even with it in the fixed section of pages i still have black background
                    A Former User
                    and so? what can i do? I have to configure MMM-pages or MMM-Carousel ?
                    explain me …
                    GAB is not a module, it’s just a recipe for GA … so there is no config in config.js…
                    explain me why do you want fixed: [] GAB ?? only GA have a config…
                      banbutcher @Guest
                      if GAB is not a module then why do i need to config mmm-pages correctly?
                      i have GA set to “fullscreen_above” and the “with-BackgroundStatus” in the recipe queue.
                      i think GA is working like it should, however i dont see the google assistant & logo (like before pic below) i just see black where google logo is…
                      @Bugsounet said in MMM-GABackgound -- Allow Change GoogleAssistant Background:
                      sorry if im being stupid
                        A Former User
                        @banbutcher said in MMM-GABackgound -- Allow Change GoogleAssistant Background:
                        do you see a MMM-GaBackground.js and node_helper.js there !? NO ! so it’s not a MODULE … installer copy 2 recipes in MMM-GoogleAssistant Directory !
                        this 2 recipes redirect for playing gifs in each directory : sample for jarvis: there
                        BUT ! I YOU DON’T have this picture WITHOUT MMM-GABackground
                        IT’S MEANS MMM-GoogleAssistant is not correctly CONFIGURED with MMM-pages !
                        Because YOU MUST have the background …
                        And if you don’t have this background … YOU CAN’T USE MMM-GABackground !
                        Correct your MMM-GoogleAssistant ISSUE FIRST !
                        it’s the default background of MMM-GoogleAssistant !!!
                        You can’t change a background to an hidden module
                        Actually only MMM-GoogleAssistant popups is displayed (and no modules can prohibits it to display … because it’s a popup and don’t use config.js position of the module)
                        so, The module is not displayed … the module is: THE BACKGROUND !
