    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 40.6k Views 2 Watching
    • E
      ember1205
      One tweak to the run-start.sh script seems to have fixed it. I changed this line:
      serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\'\\r)
      To this:
      serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($1)}' | tr -d ,\"\'\\r)
      The awk command seems to have been looking for a variable that wasn’t being passed and by changing the variable number that it was looking for, it no longer starts electron and now starts chromium.
        sdetweil @ember1205
        @ember1205 hm… do this
        ./run-start.sh
        you should see something like this
         ./run-start.sh
        [2020-09-22 13:13:51.584] [LOG] Starting MagicMirror: v2.13.0-develop
        [2020-09-22 13:13:51.588] [LOG] Loading config ...
        [2020-09-22 13:13:51.590] [LOG] Loading module helpers ...
        [2020-09-22 13:13:51.590] [LOG] No helper found for module: alert.
        [2020-09-22 13:13:51.602] [LOG] Initializing new module helper ...
        [2020-09-22 13:13:51.602] [LOG] Module helper loaded: updatenotification
        [2020-09-22 13:13:51.603] [LOG] No helper found for module: clock.
        [2020-09-22 13:13:51.840] [LOG] Initializing new module helper ...
        [2020-09-22 13:13:51.840] [LOG] Module helper loaded: calendar
        [2020-09-22 13:13:51.841] [LOG] No helper found for module: compliments.
        [2020-09-22 13:13:51.841] [LOG] No helper found for module: currentweather.
        [2020-09-22 13:13:51.841] [LOG] No helper found for module: weatherforecast.
        [2020-09-22 13:13:52.147] [LOG] Initializing new module helper ...
        [2020-09-22 13:13:52.147] [LOG] Check MagicMirror version for node helper 'MMM-Ring' - Minimum version: 2.11.0 - Current version: 2.13.0-develop
        [2020-09-22 13:13:52.147] [LOG] Version is ok!
        [2020-09-22 13:13:52.148] [LOG] Module helper loaded: MMM-Ring
        [2020-09-22 13:13:52.148] [LOG] All module helpers loaded.
        [2020-09-22 13:13:52.186] [LOG] Starting server on port 8090 ...
        [2020-09-22 13:13:52.187] [INFO] You're using a full whitelist configuration to allow for all IPs
        [2020-09-22 13:13:52.190] [LOG] Server started ...
        [2020-09-22 13:13:52.190] [LOG] Connecting socket for: updatenotification
        [2020-09-22 13:13:52.190] [LOG] Connecting socket for: calendar
        [2020-09-22 13:13:52.190] [LOG] Starting node helper for: calendar
        [2020-09-22 13:13:52.191] [LOG] Connecting socket for: MMM-Ring
        [2020-09-22 13:13:52.196] [LOG] MMM-Ring at (9/22/2020, 1:13:52 PM): Starting module: MMM-Ring
        [2020-09-22 13:13:52.196] [LOG] Sockets connected & modules started ...
        Ready to go! Please point your browser to: http://0.0.0.0:8090
        Starting chromium browser now, have patience, it takes a minute
        that last line is the key to running in split mode, server with chromium over the top…
        to run it multiple times, you will have to kill the server process
         ps -ef | grep server
        sam 3267 3266 1 13:13 pts/0 00:00:01 node serveronly
        kill -9 3267
        thx for the hint, the space after the serverOnly:
          @ember1205 I just updated the script to handle with/without the space…
          • E
            ember1205
            Cool. I download the latest one and try it out.
            Glad I can help you keep improving your code! lol
              sdetweil @ember1205
              @ember1205 said in "Out of memory" issues - where do I begin?:
              me too… thought I had handled that… guess not
              • E
                ember1205
                Based on the directions you gave in this thread, the run-start.sh script won’t work. I didn’t take the time to look through the github content to see if this is covered there, but you have to do
                chmod +x run-start.sh
                Or the script won’t actually execute. Based on old habits, I was executing the chmod statement without even thinking about it. But, after downloading the newest script, I purposefully left it untouched and it wouldn’t run.
                  sdetweil @ember1205
                  @ember1205 hm, thought it was uploaded with exec. will check this evening. have doctor appt shortly
                  thanks for the info
                  • E
                    ember1205
                    I simply opened the github page, copied the link, and used wget to download it to the mirror. So, it’s entirely possible that the way I downloaded it was partly to blame. Figured I would mention it because I’m likely not the only one that might run into this, and at a minimum it could become a troubleshooting step if others run into issues.
                      sdetweil @ember1205
                      @ember1205 thx. wget & curl won’t copy the execute permissions. when I install this on a pi 0 I chmod it to executable
                      • E
                        ember1205
                        You can’t make this stuff up…
                        Mirror has been running for a couple of hours now without crashing as it has been doing intermittently in the past. However, there is now a “pop up” on the screen stating that Chromium couldn’t be updated and that I’m missing out on features and fixes.
                        I found what might be a fix in the way of potentially “configuring” Chromium to ignore updates, but I won’t know if this truly works until probably tomorrow at the earliest.
                        • E
                          ember1205
                          I’m now about 2.5 days into two MM’s running without crashes using Chromium instead of Electron. I’ve also not seen a return of the pop up from Chromium about needing to be updated.
                          For those that might need to correct the update issue, here’ s what I did on my mirrors:
                          sudo touch /etc/chromium-browser/customizations/01-disable-update-check;echo CHROMIUM_FLAGS=\"\$\{CHROMIUM_FLAGS\} --check-for-update-interval=31536000\" | sudo tee /etc/chromium-browser/customizations/01-disable-update-check
                            sdetweil @ember1205
                            @ember1205 cool. thx for that info. I will add it to my install script for pi0!!
                            • E
                              ember1205
                              UPDATE: At this point, I’m closing in on a full week of operating two mirrors without issue. I’ve changed to running Chromium instead of Electron and it’s working well all around. Here are some details of the operation in case it’s useful:
                              • Pi 3 Model B (one UK, one China)
                              • MM 2.12.0
                              • Native modules configured: WeatherForecast, CurrentWeather (both weather modules set to different locations as the two Pi’s are in different locations), clock, calendar (2 instances, 2 different Google calendars), alert, updatenotification
                              • Third-party modules: MMM-ImagesPhotos (@sdetweil version)
                              • Customizations:
                                • Modified the WeatherForecast module according to this thread to get 5 days of forecast data back after recent MM update: https://forum.magicmirror.builders/topic/13187/weatherforecast-showing-only-two-days/31?_=1601303807634
                                • Converted to using Chromium instead of Electron locally as detailed in this thread
                                • Chromium update / notice disabled via the step from a couple of posts prior to this one
                                • Allow connections from local LAN addresses
                              • Pi connected to a smart plug that turns on each day at 7AM, cron job to execute “init 0” each day at 11PM, smart plug turns off at 11:05PM
                              Prior to successfully switching over to Chromium, the devices would crash at least once every other day (at least one of them would crash during a 48 hour window), although it was much more common to see each one crash multiple times per day. There was no consistency to which one would crash, why, when, etc. The “crash” in question was a black screen on the mirror and no visible info being output although the mouse cursor would sometimes appear. I wrote a cron job that would run every five minutes, look up the location of the pm2 error logs, check to see if there was an “out of memory” error in the log, and do a restart of MM if there was (the restart consisted of shut down, log flush, and start). This job ran every five minutes and would silently exit if there was no error as the mirror was running ok.
                              Since the switchover, I have seen zero crashes on either device in almost seven days of operation.
                              Electron has been discussed ad nauseum as having a variety of shortcomings, bugs, issues, etc. - especially in the old version being used with MM. At this point, I have to wonder why it’s still not only the default but the ‘only’ browser that’s really discussed for use with MM. It would seem that it’s time to either forklift an upgrade to it within MM or switch to something else (at a minimum, at least provide a well-documented alternative).
                              I’m grateful to @sdetweil for his assistance with this, especially since it really took a calendar year almost to get to a point where it’s seemingly working as expected now.
                                sdetweil @ember1205
                                @ember1205 sometimes upgrading one part causes forced upgrades to others and the collection brings more problems…
                                E 1 Reply Last reply
                                • E
                                  ember1205 @sdetweil
                                  @sdetweil I can appreciate that - I work for a software company, and know about inter-dependencies and the headaches they can cause.
                                  MM is, in a very basic sense, a web server. Electron is a web browser. There shouldn’t be inter-dependencies between a web server and browser, and that seems to be apparent with Chromium not having an issue running against the MM server. So, I would hope that Electron could be brought forward or at least Chromium be documented as an solid alternative.
                                    sdetweil @ember1205
                                    @ember1205 I got us moved from V3 to V6… we need to add another cycle… it didn’t work with V7 last time.
                                    • E
                                      ember1205 @sdetweil
                                      @sdetweil v10 is out and listed as “stable”.
                                        sdetweil @ember1205
                                        @ember1205 yeh, that and a quarter!!.. V7 was stable when we tried it last year too… running on PI is a whole different thing… they test on x86.
                                        • E
                                          ember1205
                                          Update… 30 full days since my last post about stability and have not experienced a single crash on either mirror. So, Electron is definitely the source of the problem.
                                          Thank you to @sdetweil for the assistance in swapping over to Chromium and getting things to a stable state.
                                            sdetweil @ember1205
                                            @ember1205 thank you for the feedback… there is a proposal to move to Electron V10
                                            • 3 / 4
