    "Out of memory" issues - where do I begin?
    65 Posts 2 Posters 39.6k Views 2 Watching
    • E Offline
      ember1205
      Good info.
      I’m interested to see how for the MM will make it now using Chromium instead of Electron. Since I have two with the same setup, I’ll set both to use Chromium for an additional level of testing it out.
      Why was Electron chosen as the browser up to this point? And, what potential downsides are there to Chromium?
        sdetweil @ember1205
        @ember1205 >Why was Electron chosen as the browser up to this point? And, what potential downsides are there to Chromium?
        i don’t know and i don’t know… was way before my time.
        • E Offline
          ember1205
          Welp…
          No change. System still crashes on the Pi using Chromium.
          In looking at the most recent core file, it’s still showing that electron is what’s faulting.
          There are no running processes of chromium and electron is still being started. Something is amiss with the configuration to where your run-start.sh script is either not being called or is not launching the correct browser for some reason.
          I’ve made no changes to run-start.sh, I’ve edited package.json so that this line is gone:
          And has been replaced with this one:
          "start": "./run-start.sh",
          config/config.js has the following setting:
          var config = {
          	address: "0.0.0.0", 	// Address to listen on, can be:
          							// - "localhost", "127.0.0.1", "::1" to listen on loopback interfac
          e
          							// Default, when address config is left out or empty, is "localhost
          	port: 8080,
          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "192.168.192.0/24", "::1"], 	// Set [] to allow all IP addresses
          or add a specific IPv4 of 192.168.1.5 :
          ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
          or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
          ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
          	language: "en",
          	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          	timeFormat: 24,
          	units: "metric",
          	serverOnly:"local",
          • E Offline
            ember1205
            One tweak to the run-start.sh script seems to have fixed it. I changed this line:
            serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($2)}' | tr -d ,\"\'\\r)
            To this:
            serveronly=$(grep -v '^[[:blank:]]*//'  config/config.js | grep -i serveronly: | awk '{print tolower($1)}' | tr -d ,\"\'\\r)
            The awk command seems to have been looking for a variable that wasn’t being passed and by changing the variable number that it was looking for, it no longer starts electron and now starts chromium.
              sdetweil @ember1205
              @ember1205 hm… do this
              ./run-start.sh
              you should see something like this
               ./run-start.sh
              [2020-09-22 13:13:51.584] [LOG] Starting MagicMirror: v2.13.0-develop
              [2020-09-22 13:13:51.588] [LOG] Loading config ...
              [2020-09-22 13:13:51.590] [LOG] Loading module helpers ...
              [2020-09-22 13:13:51.590] [LOG] No helper found for module: alert.
              [2020-09-22 13:13:51.602] [LOG] Initializing new module helper ...
              [2020-09-22 13:13:51.602] [LOG] Module helper loaded: updatenotification
              [2020-09-22 13:13:51.603] [LOG] No helper found for module: clock.
              [2020-09-22 13:13:51.840] [LOG] Initializing new module helper ...
              [2020-09-22 13:13:51.840] [LOG] Module helper loaded: calendar
              [2020-09-22 13:13:51.841] [LOG] No helper found for module: compliments.
              [2020-09-22 13:13:51.841] [LOG] No helper found for module: currentweather.
              [2020-09-22 13:13:51.841] [LOG] No helper found for module: weatherforecast.
              [2020-09-22 13:13:52.147] [LOG] Initializing new module helper ...
              [2020-09-22 13:13:52.147] [LOG] Check MagicMirror version for node helper 'MMM-Ring' - Minimum version: 2.11.0 - Current version: 2.13.0-develop
              [2020-09-22 13:13:52.147] [LOG] Version is ok!
              [2020-09-22 13:13:52.148] [LOG] Module helper loaded: MMM-Ring
              [2020-09-22 13:13:52.148] [LOG] All module helpers loaded.
              [2020-09-22 13:13:52.186] [LOG] Starting server on port 8090 ...
              [2020-09-22 13:13:52.187] [INFO] You're using a full whitelist configuration to allow for all IPs
              [2020-09-22 13:13:52.190] [LOG] Server started ...
              [2020-09-22 13:13:52.190] [LOG] Connecting socket for: updatenotification
              [2020-09-22 13:13:52.190] [LOG] Connecting socket for: calendar
              [2020-09-22 13:13:52.190] [LOG] Starting node helper for: calendar
              [2020-09-22 13:13:52.191] [LOG] Connecting socket for: MMM-Ring
              [2020-09-22 13:13:52.196] [LOG] MMM-Ring at (9/22/2020, 1:13:52 PM): Starting module: MMM-Ring
              [2020-09-22 13:13:52.196] [LOG] Sockets connected & modules started ...
              Ready to go! Please point your browser to: http://0.0.0.0:8090
              Starting chromium browser now, have patience, it takes a minute
              that last line is the key to running in split mode, server with chromium over the top…
              to run it multiple times, you will have to kill the server process
               ps -ef | grep server
              sam 3267 3266 1 13:13 pts/0 00:00:01 node serveronly
              kill -9 3267
              thx for the hint, the space after the serverOnly:
                @ember1205 I just updated the script to handle with/without the space…
                • E Offline
                  ember1205
                  Cool. I download the latest one and try it out.
                  Glad I can help you keep improving your code! lol
                    sdetweil @ember1205
                    @ember1205 said in "Out of memory" issues - where do I begin?:
                    me too… thought I had handled that… guess not
                    • E Offline
                      ember1205
                      Based on the directions you gave in this thread, the run-start.sh script won’t work. I didn’t take the time to look through the github content to see if this is covered there, but you have to do
                      chmod +x run-start.sh
                      Or the script won’t actually execute. Based on old habits, I was executing the chmod statement without even thinking about it. But, after downloading the newest script, I purposefully left it untouched and it wouldn’t run.
                        sdetweil @ember1205
                        @ember1205 hm, thought it was uploaded with exec. will check this evening. have doctor appt shortly
                        thanks for the info
                        • E Offline
                          ember1205
                          I simply opened the github page, copied the link, and used wget to download it to the mirror. So, it’s entirely possible that the way I downloaded it was partly to blame. Figured I would mention it because I’m likely not the only one that might run into this, and at a minimum it could become a troubleshooting step if others run into issues.
                            sdetweil @ember1205
                            @ember1205 thx. wget & curl won’t copy the execute permissions. when I install this on a pi 0 I chmod it to executable
                            • E Offline
                              ember1205
                              You can’t make this stuff up…
                              Mirror has been running for a couple of hours now without crashing as it has been doing intermittently in the past. However, there is now a “pop up” on the screen stating that Chromium couldn’t be updated and that I’m missing out on features and fixes.
                              I found what might be a fix in the way of potentially “configuring” Chromium to ignore updates, but I won’t know if this truly works until probably tomorrow at the earliest.
                              • E Offline
                                ember1205
                                I’m now about 2.5 days into two MM’s running without crashes using Chromium instead of Electron. I’ve also not seen a return of the pop up from Chromium about needing to be updated.
                                For those that might need to correct the update issue, here’ s what I did on my mirrors:
                                sudo touch /etc/chromium-browser/customizations/01-disable-update-check;echo CHROMIUM_FLAGS=\"\$\{CHROMIUM_FLAGS\} --check-for-update-interval=31536000\" | sudo tee /etc/chromium-browser/customizations/01-disable-update-check
                                  sdetweil @ember1205
                                  @ember1205 cool. thx for that info. I will add it to my install script for pi0!!
                                  • E Offline
                                    ember1205
                                    UPDATE: At this point, I’m closing in on a full week of operating two mirrors without issue. I’ve changed to running Chromium instead of Electron and it’s working well all around. Here are some details of the operation in case it’s useful:
                                    • Pi 3 Model B (one UK, one China)
                                    • MM 2.12.0
                                    • Native modules configured: WeatherForecast, CurrentWeather (both weather modules set to different locations as the two Pi’s are in different locations), clock, calendar (2 instances, 2 different Google calendars), alert, updatenotification
                                    • Third-party modules: MMM-ImagesPhotos (@sdetweil version)
                                    • Customizations:
                                      • Modified the WeatherForecast module according to this thread to get 5 days of forecast data back after recent MM update: https://forum.magicmirror.builders/topic/13187/weatherforecast-showing-only-two-days/31?_=1601303807634
                                      • Converted to using Chromium instead of Electron locally as detailed in this thread
                                      • Chromium update / notice disabled via the step from a couple of posts prior to this one
                                      • Allow connections from local LAN addresses
                                    • Pi connected to a smart plug that turns on each day at 7AM, cron job to execute “init 0” each day at 11PM, smart plug turns off at 11:05PM
                                    Prior to successfully switching over to Chromium, the devices would crash at least once every other day (at least one of them would crash during a 48 hour window), although it was much more common to see each one crash multiple times per day. There was no consistency to which one would crash, why, when, etc. The “crash” in question was a black screen on the mirror and no visible info being output although the mouse cursor would sometimes appear. I wrote a cron job that would run every five minutes, look up the location of the pm2 error logs, check to see if there was an “out of memory” error in the log, and do a restart of MM if there was (the restart consisted of shut down, log flush, and start). This job ran every five minutes and would silently exit if there was no error as the mirror was running ok.
                                    Since the switchover, I have seen zero crashes on either device in almost seven days of operation.
                                    Electron has been discussed ad nauseum as having a variety of shortcomings, bugs, issues, etc. - especially in the old version being used with MM. At this point, I have to wonder why it’s still not only the default but the ‘only’ browser that’s really discussed for use with MM. It would seem that it’s time to either forklift an upgrade to it within MM or switch to something else (at a minimum, at least provide a well-documented alternative).
                                    I’m grateful to @sdetweil for his assistance with this, especially since it really took a calendar year almost to get to a point where it’s seemingly working as expected now.
                                      sdetweil @ember1205
                                      @ember1205 sometimes upgrading one part causes forced upgrades to others and the collection brings more problems…
                                      • E Offline
                                        ember1205 @sdetweil
                                        @sdetweil I can appreciate that - I work for a software company, and know about inter-dependencies and the headaches they can cause.
                                        MM is, in a very basic sense, a web server. Electron is a web browser. There shouldn’t be inter-dependencies between a web server and browser, and that seems to be apparent with Chromium not having an issue running against the MM server. So, I would hope that Electron could be brought forward or at least Chromium be documented as an solid alternative.
                                          sdetweil @ember1205
                                          @ember1205 I got us moved from V3 to V6… we need to add another cycle… it didn’t work with V7 last time.
                                          • E Offline
                                            ember1205 @sdetweil
                                            @sdetweil v10 is out and listed as “stable”.
                                            • 3 / 4
