    module.js
    7 Posts 2 Posters 778 Views 1 Watching
      A Former User
        sdetweil @Guest
        @hango no… the MM functions locate modules
        then u have the module object and call hide on it
        from my SleepWake module
        MM.getModules().enumerate((module) => {
        				// if the module is already hidden
        				if(module.hidden==true)
        					// save it for wake up
        					{self.previously_hidden.push(module.identifier);}
        				else
        					// hide this module
        					{module.hide(1000);}
        https://docs.magicmirror.builders/development/helper-methods.html#module-selection
          A Former User
            sdetweil @Guest
            @hango from main.js
            var showModule = function (module, speed, callback, options) {
            var hideModule = function (module, speed, callback, options) {
              A Former User
                sdetweil @Guest
                @hango before the call to hideModule
                there is a variable self set
                self is used to avoid the ambiguity of ‘this’, as inside callbacks ‘this’ can point to the caller, NOT the context where it was intended.
                	var self = this;     < ----- self is initialized to the current 'this' context
                	MM.hideModule(
                		self,              < -------------- should be 'this' ?
                		speed,
                so its the same
                and in the call there is a required function (the callback), in this case created inline
                		function () {
                			self.suspend();   // < --- make sure to use the right module context when this function is called
        // the compiler remembers that self was defined above
                			callback();         // call the routine defined as callback
                  A Former User
