module.js
7 Posts 2 Posters 611 Views 1 Watching
    A Former User
    S 1 Reply Last reply Sep 29, 2020, 12:32 PM Reply Quote 0
      sdetweil @Guest
      @hango no… the MM functions locate modules
      then u have the module object and call hide on it
      from my SleepWake module
      MM.getModules().enumerate((module) => {
      				// if the module is already hidden
      				if(module.hidden==true)
      					// save it for wake up
      					{self.previously_hidden.push(module.identifier);}
      				else
      					// hide this module
      					{module.hide(1000);}
      https://docs.magicmirror.builders/development/helper-methods.html#module-selection
        A Former User
        S 1 Reply Last reply Sep 29, 2020, 12:40 PM Reply Quote 0
          sdetweil @Guest
          @hango from main.js
          var showModule = function (module, speed, callback, options) {
          var hideModule = function (module, speed, callback, options) {
            A Former User
            S 1 Reply Last reply Sep 29, 2020, 12:59 PM Reply Quote 0
              sdetweil @Guest
              @hango before the call to hideModule
              there is a variable self set
              self is used to avoid the ambiguity of ‘this’, as inside callbacks ‘this’ can point to the caller, NOT the context where it was intended.
              	var self = this;     < ----- self is initialized to the current 'this' context
              	MM.hideModule(
              		self,              < -------------- should be 'this' ?
              		speed,
              so its the same
              and in the call there is a required function (the callback), in this case created inline
              		function () {
              			self.suspend();   // < --- make sure to use the right module context when this function is called
        // the compiler remembers that self was defined above
              			callback();         // call the routine defined as callback
                A Former User
