    Calendar failed to load Gmail ical
    4 Posts 2 Posters 491 Views 3 Watching
      barucomx
      Re: Calendar failed to load.
      in the solution provided by @sdetweil worked wonderfully on old versions of MagicMirror, but in a brand new instalation I got the same error but does not work at all adding the case ‘’: to the file /home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js
      Any suggestions? 🙂
      [2020-10-02 01:54:04.535] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
      [2020-10-02 01:54:08.276] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-02 01:54:08.277] [ERROR]  Error: Unknown RRULE property 'RRULE'
          at /home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1191:23
          at Array.forEach (<anonymous>)
          at parseRrule (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1149:11)
          at parseLine (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1138:20)
          at Array.map (<anonymous>)
          at Function.parseString (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:1110:41)
          at Function.RRule.fromString (/home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js:2135:32)
          at Object.END (/home/pi/MagicMirror/node_modules/node-ical/ical.js:446:30)
          at Object.handleObject (/home/pi/MagicMirror/node_modules/node-ical/ical.js:483:39)
          at Object.parseLines (/home/pi/MagicMirror/node_modules/node-ical/ical.js:534:18)
      [2020-10-02 01:54:08.280] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-10-02 01:54:08.281] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        barucomx @barucomx
        found a ‘solution’ in the file /home/pi/MagicMirror/node_modules/node-ical/node_modules/rrule/dist/es5/rrule.js just commented the default action and now I can see the calendar :astonished_face:
                                case 'BYEASTER':
                                    options.byeaster = Number(value);
                                    break;
                                case '':
                                    break;
                                default:
                    //                throw new Error("Unknown RRULE property '" + key + "'");
          sdetweil @barucomx
          @barucomx can u send me a little ics with that one event? we have an open issue, but can’t recreate it…
            sdetweil @barucomx
            @barucomx i need a short ics file from you that causes this problem so we can fix it…
