    MagicMirror Newsfeed continually "loading"...
    24 Posts 4 Posters 12.3k Views 4 Watching
      sdetweil @ForeverBrewing
      @ForeverBrewing i am trying to test here for info…
        if you do a
        pm2 stop 0
        then from a command prompt, even over ssh
        npm start
        you will see messages , here is the default set of stuff,
        see that last entry
        Starting MagicMirror: v2.9.0
        Loading config ...
        Loading module helpers ...
        All module helpers loaded.
        You're using a full whitelist configuration to allow for all IPs
        Server started ...
        Starting module: newsfeed
        Launching application.
        Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        F 1 Reply Last reply
        • F
          ForeverBrewing @sdetweil
          Nope, I’m missing the last two lines:
          pi@raspberrypi:~/MagicMirror $ pm2 stop 0
          npm start [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
          [PM2] PM2 Successfully daemonized
          [PM2] Applying action stopProcessId on app [0](ids: 0)
          [PM2][ERROR] Process 0 not found
          > magicmirror@2.9.0 start /home/pi/MagicMirror
          > sh run-start.sh
          Loading config ...
          No helper found for module: helloworld.
          Server started ...
          Also looks like the helper module doesn’t get loaded…?
            @ForeverBrewing ok, can u do
            ls ~/MagicMirror/config -laF
            ls ~/MagicMirror/modules/default -laF
            • F
              @sdetweil said in MagicMirror Newsfeed continually "loading"...:
              pi@raspberrypi:~/MagicMirror $ ls ~/MagicMirror/config -laF
              total 20
              drwxr-xr-x  2 pi pi 4096 Nov 13 18:17 ./
              drwxr-xr-x 17 pi pi 4096 Nov 12 20:25 ../
              -rw-r--r--  1 pi pi 3437 Nov 13 17:35 config.js
              -rw-r--r--  1 pi pi 2769 Nov 10 14:36 config.js.sample
              -rw-r--r--  1 pi pi   20 Nov 10 14:36 .gitignore
              pi@raspberrypi:~/MagicMirror $ ls ~/MagicMirror/modules/default -laF
              total 52
              drwxr-xr-x 12 pi pi 4096 Nov 12 21:29 ./
              drwxr-xr-x  6 pi pi 4096 Nov 10 18:20 ../
              drwxr-xr-x  3 pi pi 4096 Nov 10 14:36 alert/
              drwxr-xr-x  3 pi pi 4096 Nov 10 14:36 calendar/
              drwxr-xr-x  3 pi pi 4096 Nov 10 14:36 clock/
              drwxr-xr-x  2 pi pi 4096 Nov 10 16:35 compliments/
              drwxr-xr-x  2 pi pi 4096 Nov 10 14:36 currentweather/
              -rw-r--r--  1 pi pi  520 Nov 10 14:36 defaultmodules.js
              drwxr-xr-x  2 pi pi 4096 Nov 10 14:36 helloworld/
              drwxr-xr-x  2 pi pi 4096 Nov 12 21:32 newsfeed/
              drwxr-xr-x  2 pi pi 4096 Nov 10 14:36 updatenotification/
              drwxr-xr-x  3 pi pi 4096 Nov 10 14:36 weather/
              drwxr-xr-x  2 pi pi 4096 Nov 10 14:36 weatherforecast/
              Thank you so much for your time with this btw :)
                @ForeverBrewing said in MagicMirror Newsfeed continually "loading"...:
                no problem… like to help…
                but the output doesn’t match the config at all… there should be more info about the other modules and errors if they were not found…
                • F
                  Well I guess installing a fresh copy wont be too much hassle! Its not like I cant work out how to get the google assistant to work anyway, so I’ll probably just keep it completely vanilla. Even I cant balls that up too much…
                    @ForeverBrewing use the updated installer… see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                    you should rename the current MM folder out of the way… then u can copy files over if need be
                    • F
                      Will do, thanks for your help :)
                        spblat
                        For those googling this problem, consider whether you added the module to your config file but didn’t stop and restart the software. Many config changes can take effect just by saving the config file and reloading the browser window, but adding and removing modules…not so much :-)
                        Reply Quote 2
                          sdetweil @spblat
                          @spblat if the module has a node_helper.js, you need to restart MM for any changes to take place
                          Reply Quote 2
                          • ParvezP
                            Parvez
                            Just reinstall this modules
                            i things solved this problem
                            cd ~/MagicMirror/modules/default/newsfeed/
                            npm install
                            Parvez Ahmed
                              sdetweil @Parvez
                              @Parvez no. no package.json there
                              that is part of the base mm
                              • ParvezP
                                Parvez
                                @sdetweil can you help me … install problem MMM Hotword
                                Welcome to Hotword v2.4.0
                                Checking OS...
                                OS Detected: linux-gnueabihf (raspbian 10 armv7l)
                                Do you want to execute automatic intallation ? [Y/n]
                                Your choice: N
                                npm ERR! code E404
                                npm ERR! 404 Not Found - GET https://registry.npmjs.org/@bugsounet%2flpcm16 - Not found
                                npm ERR! 404
                                npm ERR! 404  '@bugsounet/lpcm16@^1.0.1' is not in the npm registry.
                                npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                npm ERR! 404 It was specified as a dependency of 'MMM-Hotword'
                                npm ERR! 404
                                npm ERR! 404 Note that you can also install from a
                                npm ERR! 404 tarball, folder, http url, or git url.
                                npm ERR!     /home/pi/.npm/_logs/2020-10-03T05_32_52_379Z-debug.log
                                Parvez Ahmed
                                  sdetweil @Parvez
                                  @Parvez hotword has been removed, and is no longer available.
                                  to use GoogleAssistant you have to install MMM-GoogleAssistant
                                  .also bugsounet has removed some of his modules
