    Error with Outlook Calendar
    23 Posts 3 Posters 8.5k Views 3 Watching
      bokchok
      I can’t get an outlook calendar to work with the defualt calendar module. The events just won’t show up. The console error is:
      [2020-10-02 22:45:26.002] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-02 22:45:26.003] [ERROR]  TypeError: Cannot read property 'iana' of undefined
          at getIanaTZFromMS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:108:30)
          at /home/pi/MagicMirror/node_modules/node-ical/ical.js:175:23
          at Object.DTSTART (/home/pi/MagicMirror/node_modules/node-ical/ical.js:457:32)
          at Object.handleObject (/home/pi/MagicMirror/node_modules/node-ical/ical.js:483:39)
          at Object.parseLines (/home/pi/MagicMirror/node_modules/node-ical/ical.js:534:18)
          at Object.parseICS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:590:18)
          at Object.sync.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:190:15)
          at Object.autodetect.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:221:17)
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:79:22)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
      The config I have for calendar the calendar module is:
                              header: "Today",
                                                      //holidays
                                                      symbol: "calendar",
                                                      url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                                      //NEC
                                                      symbol: "music",
                                                      url: "private_url.ics"
                                      maximumEntries: 25,
                                      maximumNumberOfDays: 1,
                                      fade: false,
                                      getRelative: 0,
                                      animationSpeed: 1000,
        sdetweil @bokchok
        @bokchok can you show me/send the ics file.
        are you on version 2.13, or the test iCal version?
        I fixed that bug in the node-ical version
          bokchok @sdetweil
          @sdetweil I’m on 2.13. I went ahead and set you the ics file
            sdetweil @bokchok
            @bokchok thanks, will look at it
              @sdetweil can u verify on 2.13, cause the fix for that is in 2.13
              grep version ~/MagicMirror/package.json
              and how did u get there? install or upgrade?
              • Y Offline
                Yunalescar
                Had same issues.
                had a long search and found the soultion:
                get latest version of ical.js and copy/write it to ~/MagicMirror/node_modules/node-ical.ical.js
                Link : https://raw.githubusercontent.com/jens-maus/node-ical/master/ical.js
                now it works like a charm ;)
                  bokchok @sdetweil
                  @sdetweil I was having trouble with upgrading, so I saved config.js in a separate directory and did a clean install of MagicMirror two days ago. Everything should be up to date
                    bokchok @Yunalescar
                    @Yunalescar Worked! Thank you sir
                      sdetweil @bokchok
                      @bokchok but. please, lets fix that… I updated both the node-ical libs and the ical.js libs with the same code to handle windows timezones…
                      we ship node-ical with MM… (new in this release)
                      and I checked the latest 0.12.1
                        @bokchok @Yunalescar can u look at the package.json in
                        ~/MagicMirror/node_modules/node-ical/package.json
                        what is the version number? should be 0.12.1 (which has the fix for the error) 0.12.0 does not have the fix…
                        B Y 2 Replies Last reply Reply Quote 0
                          bokchok @sdetweil
                          @sdetweil The version nmber is 0.12.0
                          When was 0.12.1 released?
                            sdetweil @bokchok
                            @bokchok 10 days ago. mm was 2 days ago
                              bokchok @sdetweil
                              @sdetweil Weird. I thought I updated after then. I’ll do another clean install and see what happens
                                @bokchok the other thing is, the error means that some cal entry is using a timezone which is not registered in the authorized windows timezone names
                                  sdetweil @bokchok
                                  @bokchok i just checked on an install I did thursday
                                  grep version MagicMirror/node_modules/node-ical/package.json
                                  “version”: “0.12.1”,
                                  ls MagicMirror/node_modules/node-ical/package.json -laF
                                  -rw-r–r-- 1 pi pi 2159 Oct 1 08:24 MagicMirror/node_modules/node-ical/package.json
                                    @sdetweil @bokchok the develop version probably would have pulled in 0.12.0 sometime last week…
                                    but your ics presented other timezone problems for another fix I am working on, so I fixed that too
                                      bokchok @sdetweil
                                      @sdetweil Did a clean install, for some reason I have 0.12.0 again. I’m not getting the error, though…
                                      • Y Offline
                                        Yunalescar @sdetweil
                                        @sdetweil said in Error with Outlook Calendar:
                                        its “node-ical@0.12.0”
                                        so with the installcall i get an old version? did a fresh install just 12 hours ago and its still 0.12.0
                                          sdetweil @Yunalescar
                                          @Yunalescar weird
                                            ok, looks like it’s my fault. I forgot to update the line in package.json here,
                                            so it only downloads 0.12.0
                                            why I get 0.12.1 I don’t know…
                                            I will fix my install and upgrade scripts, but
                                            will have to write a troubleshooting post for this
                                            thanks guys
