    Error with Outlook Calendar
    23 Posts 3 Posters 10.1k Views 3 Watching
      @bokchok @Yunalescar can u look at the package.json in
      ~/MagicMirror/node_modules/node-ical/package.json
      what is the version number? should be 0.12.1 (which has the fix for the error) 0.12.0 does not have the fix…
      B Y 2 Replies Last reply
        bokchok @sdetweil
        @sdetweil The version nmber is 0.12.0
        When was 0.12.1 released?
          sdetweil @bokchok
          @bokchok 10 days ago. mm was 2 days ago
          B 1 Reply Last reply
            bokchok @sdetweil
            @sdetweil Weird. I thought I updated after then. I’ll do another clean install and see what happens
            S 2 Replies Last reply
              @bokchok the other thing is, the error means that some cal entry is using a timezone which is not registered in the authorized windows timezone names
                sdetweil @bokchok
                @bokchok i just checked on an install I did thursday
                grep version MagicMirror/node_modules/node-ical/package.json
                “version”: “0.12.1”,
                ls MagicMirror/node_modules/node-ical/package.json -laF
                -rw-r–r-- 1 pi pi 2159 Oct 1 08:24 MagicMirror/node_modules/node-ical/package.json
                  @sdetweil @bokchok the develop version probably would have pulled in 0.12.0 sometime last week…
                  but your ics presented other timezone problems for another fix I am working on, so I fixed that too
                    bokchok @sdetweil
                    @sdetweil Did a clean install, for some reason I have 0.12.0 again. I’m not getting the error, though…
                    • Y
                      Yunalescar @sdetweil
                      @sdetweil said in Error with Outlook Calendar:
                      its “node-ical@0.12.0”
                      so with the installcall i get an old version? did a fresh install just 12 hours ago and its still 0.12.0
                        sdetweil @Yunalescar
                        @Yunalescar weird
                          ok, looks like it’s my fault. I forgot to update the line in package.json here,
                          so it only downloads 0.12.0
                          why I get 0.12.1 I don’t know…
                          I will fix my install and upgrade scripts, but
                          will have to write a troubleshooting post for this
                          thanks guys
                            I’ve added a troubleshooting topic
                            https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users
                              sdetweil @bokchok
                              @bokchok ok, looking thru your calendar, it has a custom timezone named ‘TZID:Eastern Standard Time 1’
                              none of the calendar code knows how to handle this… we don’t lookup the time to find the real name.
                              so you will get random results. the code I added looks up the windows timezone name in the
                              unicode.org supported cross reference table to get the IANA tz name the code can handle…
                              the bug u found was that I ‘assumed’ the name would always be found… but not true…
                                bokchok @sdetweil
                                @sdetweil Good to know! I’m glad this was helpful.
