    Error with Outlook Calendar
    23 Posts 3 Posters 9.8k Views 3 Watching
      sdetweil @bokchok
      @bokchok 10 days ago. mm was 2 days ago
        bokchok @sdetweil
        @sdetweil Weird. I thought I updated after then. I’ll do another clean install and see what happens
          @bokchok the other thing is, the error means that some cal entry is using a timezone which is not registered in the authorized windows timezone names
            sdetweil @bokchok
            @bokchok i just checked on an install I did thursday
            grep version MagicMirror/node_modules/node-ical/package.json
            “version”: “0.12.1”,
            ls MagicMirror/node_modules/node-ical/package.json -laF
            -rw-r–r-- 1 pi pi 2159 Oct 1 08:24 MagicMirror/node_modules/node-ical/package.json
              @sdetweil @bokchok the develop version probably would have pulled in 0.12.0 sometime last week…
              but your ics presented other timezone problems for another fix I am working on, so I fixed that too
                bokchok @sdetweil
                @sdetweil Did a clean install, for some reason I have 0.12.0 again. I’m not getting the error, though…
                • Y Offline
                  Yunalescar @sdetweil
                  @sdetweil said in Error with Outlook Calendar:
                  ~/MagicMirror/node_modules/node-ical/package.json
                  its “node-ical@0.12.0”
                  so with the installcall i get an old version? did a fresh install just 12 hours ago and its still 0.12.0
                    sdetweil @Yunalescar
                    @Yunalescar weird
                      ok, looks like it’s my fault. I forgot to update the line in package.json here,
                      so it only downloads 0.12.0
                      why I get 0.12.1 I don’t know…
                      I will fix my install and upgrade scripts, but
                      will have to write a troubleshooting post for this
                      thanks guys
                        I’ve added a troubleshooting topic
                        https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users
                          sdetweil @bokchok
                          @bokchok ok, looking thru your calendar, it has a custom timezone named ‘TZID:Eastern Standard Time 1’
                          none of the calendar code knows how to handle this… we don’t lookup the time to find the real name.
                          so you will get random results. the code I added looks up the windows timezone name in the
                          unicode.org supported cross reference table to get the IANA tz name the code can handle…
                          the bug u found was that I ‘assumed’ the name would always be found… but not true…
                            bokchok @sdetweil
                            @sdetweil Good to know! I’m glad this was helpful.
