    Installing on a Pi Zero
    175 Posts 33 Posters 283.9k Views 33 Watching
      sdetweil @KNERD
      @KNERD script will work
      • K Offline
        KNERD
        @sdetweil said in Installing on a Pi Zero:
        script will work
        I dug out a USB to ethernet. As soon as I plug it in, I got an IP address and a good connection. After a while, the connection also broke in it also.
        I wonder if there is a power save feature on it, or it is just broken.
          sdetweil @KNERD
          @KNERD well I see power save on wifi. not seen issues on Ethernet, but USB maybe
            rick
            Up until a few days ago, MagicMirror was working fine on my Pi Zero, however for no apparent reason its now stopped.
            Having looked in the /home/pi/.pm2/logs/MagicMirror-error.log I’m seeing that it cannot find the module ‘electron’
            I’ve tried npm install in the MagicMirror folder and get this error
            Error: Failed to find Electron v6.1.12 for linux-armv6l at https://github.com/electron/electron/releases/download/v6.1.12/electron-v6.1.12-linux-armv6l.zip
            I’ve also tried a fresh install using sdetweil’s script - however I get the same error about electron.
            Can anyone help provide any pointers as to why its not working anymore?
              sdetweil @rick
              @rick sounds like an SD card failure I am sorry to say. I have never seen a recovery
                rick @sdetweil
                @sdetweil Ah - I never thought of that. I’ll try another SD card - Thanks Sam
                  Bj0rne
                  Hi, sdetweil, I just ran your script on top of the full install in this thread, now the mirror is up. Thanks!
                    akz_g
                    Hi
                    I followed the pdf instructions step by step but does not seem to work for me.
                    I started with clean install of raspbian on my Pi Z W. Followed, your instructions step by step. no errors apart from the same ones in your pdf (errors while installing dependencies). After some time the installation was complete. It asked if I want to restart, I did. Once booted back up nothing loaded even after half an hour. I navigated to localhost:8080 with no success. I also tried run serveronly/ and this didn’t help.
                    I’m not sure what I am doing wrong as it seems most people are getting it working very easily.
                    Any help would be great! Thanks
                      sdetweil @akz_g
                      @akz_g use my script. the old instructions don’t work anymore
                      see here
                        RushHour99
                        @sdetweil My Magic Mirror install on a Pi Zero has been running great. I see an alert now that there is a Magic Mirror Update available. Do I just run your upgrade-script.sh to bring my Pi Zero install up to date with Magic Mirror v2.13.0?
                          sdetweil @RushHour99
                          @RushHour99 yes, note that u have to run two times.
                            RushHour99 @sdetweil
                            Thanks! Out of curiosity, why do I need to run it 2 times? I would have missed that detail if you didn’t’ let me know.
                              @RushHour99 i don’t understand , then doc says
                              Update to next MagicMirror version from an existing MagicMirror installation
                              upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                              it should handle all the work…
                              and give you a trial run of all that, only applying changes if u request them
                              give it a try
                              this works on Mac as well, cut/paste this line into the terminal window on your device
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                              ================no changes are made to the local repo or the working copy========================
                              if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
                              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                RushHour99
                                Thanks for the reply. I did read that but it just seemed a little confusing since it was the same bash command. I haven’t run the upgrade script yet, so it might be more clear when I do but i guess the script knows if it’s been run a 2nd time?
                                  @RushHour99 its NOT the same, there is an extra parameter at the end… apply
                                    @sdetweil Thanks! It is much more clear now. My screen size truncated the “apply” parameter at the end of the line. Now that I scroll horizontally I see the “apply”. Thanks again for the feedback.
                                      @RushHour99 as folks have invested a lot of time in setting up their systems, only to have an update crash everything,
                                      I wanted to provide a ‘test’ 1st, so people might be more comfortable with what might be impacted…
                                      and NOT make changes if they don’t want to continue…
                                      all my work suffers from problems in the base that is being applied, like some new translation file comments for years old modules this time…
                                        akz_g @sdetweil
                                        see here
                                        Thanks for this @sdetweil I will try with a fresh image. Do I just run master/raspberry.sh… ?
                                        Going to try it tonight! many thanks
                                          sdetweil @akz_g
                                          @akz_g no… the script is not in the base anymore … run it directly from here
                                          it does everything, prep the system, download the code, install the dependencies, add support for pi 0,
                                          add support for starting at boot, turn off screen saver
                                            akz_g @sdetweil
                                            @sdetweil Thanks again! will let you know how I get on :)
                                            • 6 / 9
