    Installing on a Pi Zero
    175 Posts 33 Posters 300.2k Views 33 Watching
      sdetweil @KNERD
      @KNERD well I see power save on wifi. not seen issues on Ethernet, but USB maybe
        rick
        Up until a few days ago, MagicMirror was working fine on my Pi Zero, however for no apparent reason its now stopped.
        Having looked in the /home/pi/.pm2/logs/MagicMirror-error.log I’m seeing that it cannot find the module ‘electron’
        I’ve tried npm install in the MagicMirror folder and get this error
        Error: Failed to find Electron v6.1.12 for linux-armv6l at https://github.com/electron/electron/releases/download/v6.1.12/electron-v6.1.12-linux-armv6l.zip
        I’ve also tried a fresh install using sdetweil’s script - however I get the same error about electron.
        Can anyone help provide any pointers as to why its not working anymore?
          sdetweil @rick
          @rick sounds like an SD card failure I am sorry to say. I have never seen a recovery
          R 1 Reply Last reply
            rick @sdetweil
            @sdetweil Ah - I never thought of that. I’ll try another SD card - Thanks Sam
              Bj0rne
              Hi, sdetweil, I just ran your script on top of the full install in this thread, now the mirror is up. Thanks!
              • A
                akz_g
                Hi
                I followed the pdf instructions step by step but does not seem to work for me.
                I started with clean install of raspbian on my Pi Z W. Followed, your instructions step by step. no errors apart from the same ones in your pdf (errors while installing dependencies). After some time the installation was complete. It asked if I want to restart, I did. Once booted back up nothing loaded even after half an hour. I navigated to localhost:8080 with no success. I also tried run serveronly/ and this didn’t help.
                I’m not sure what I am doing wrong as it seems most people are getting it working very easily.
                Any help would be great! Thanks
                  sdetweil @akz_g
                  @akz_g use my script. the old instructions don’t work anymore
                  see here
                  A 1 Reply Last reply
                    RushHour99
                    @sdetweil said in Installing on a Pi Zero:
                    @sdetweil My Magic Mirror install on a Pi Zero has been running great. I see an alert now that there is a Magic Mirror Update available. Do I just run your upgrade-script.sh to bring my Pi Zero install up to date with Magic Mirror v2.13.0?
                      sdetweil @RushHour99
                      @RushHour99 yes, note that u have to run two times.
                        RushHour99 @sdetweil
                        Thanks! Out of curiosity, why do I need to run it 2 times? I would have missed that detail if you didn’t’ let me know.
                          @RushHour99 i don’t understand , then doc says
                          Update to next MagicMirror version from an existing MagicMirror installation
                          upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
                          it should handle all the work…
                          and give you a trial run of all that, only applying changes if u request them
                          give it a try
                          this works on Mac as well, cut/paste this line into the terminal window on your device
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                          ================no changes are made to the local repo or the working copy========================
                          if you WANT to actually apply the changes, cut/paste this line into the terminal window on your device
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                            RushHour99
                            Thanks for the reply. I did read that but it just seemed a little confusing since it was the same bash command. I haven’t run the upgrade script yet, so it might be more clear when I do but i guess the script knows if it’s been run a 2nd time?
                              @RushHour99 its NOT the same, there is an extra parameter at the end… apply
                                @sdetweil Thanks! It is much more clear now. My screen size truncated the “apply” parameter at the end of the line. Now that I scroll horizontally I see the “apply”. Thanks again for the feedback.
                                  @RushHour99 as folks have invested a lot of time in setting up their systems, only to have an update crash everything,
                                  I wanted to provide a ‘test’ 1st, so people might be more comfortable with what might be impacted…
                                  and NOT make changes if they don’t want to continue…
                                  all my work suffers from problems in the base that is being applied, like some new translation file comments for years old modules this time…
                                  • A
                                    akz_g @sdetweil
                                    see here
                                    Thanks for this @sdetweil I will try with a fresh image. Do I just run master/raspberry.sh… ?
                                    Going to try it tonight! many thanks
                                      sdetweil @akz_g
                                      @akz_g no… the script is not in the base anymore … run it directly from here
                                      it does everything, prep the system, download the code, install the dependencies, add support for pi 0,
                                      add support for starting at boot, turn off screen saver
                                      • A
                                        akz_g @sdetweil
                                        @sdetweil Thanks again! will let you know how I get on :)
                                        • A
                                          akz_g @akz_g
                                          @akz_g first message I got was
                                          this appears not to be a Raspberry Pi 2, 3 or 4, do you want to continue installation (y/N)?
                                          should I continue? don’t want to waste another hour if i’m doing it wrong.
                                            sdetweil @akz_g
                                            @akz_g no, keep going
                                            • 6 / 9
