    is custom.css only for default modules?
    13 Posts 4 Posters 3.6k Views 4 Watching
      cluelesscarter
      Hey - n00b question,
      I’ve tried doing calling modules such as MMM-MoonPhase to position them exactly and create custom backgrounds for that specific module through custom.css but I can’t get it working… Should I be editing only the modules CSS file?
      The position and the background are probably separate issues to tackle right?
      .module.MMM-MoonPhase {
        position: absolute;
        left : 400px;
        top : 100px;
       background: #545454;
        sdetweil @cluelesscarter
        @cluelesscarter only edit the custom.css
        custom.css is for everything. last stylesheet loaded so it can override anything before it
        remove the .module
        should start with the full module name
          ShuraimHassan @sdetweil
          @sdetweil How can I use Bootstrap on 3rd Party Modules??
            sdetweil @ShuraimHassan
            @ShuraimHassan what is bootstrap?
              @sdetweil What do you mean? Are you not Front end or Full stack Developer??
                @ShuraimHassan no…
                S S 2 Replies Last reply Reply Quote 0
                  @sdetweil Bootstrap is a potent front-end framework used to create modern websites and web apps. It’s open-source and free to use, yet features numerous HTML and CSS templates for UI interface elements such as buttons and forms. Bootstrap also supports JavaScript extensions.
                    @ShuraimHassan but like anything else, u install it
                    https://getbootstrap.com/
                    and for those modules that expose their icon usage, you either change the config or use css to override.
                    each module gets to do its own thing, so u have to fiddle with each one separately…
                    most use font-awesome icons…
                      @ShuraimHassan each module provides a block of html in a div wrapper.
                      the MM runtime positions the block of content where u configured it. (see index.html for the layout)
                      you can also use javascript api calls to create the content that is returned to MM on the getDom() routine.
                      i would say probably >95% of the MM implementations are output only … (as its a ‘mirror’ hanging on the wall, probably 95% of the other 5% are voice based
                      as many are behind shaded glass, the cool color front ends don’t display well, and aren’t particularly helpful to this kind of environment… …
                        @sdetweil could you show me an Example that how Can I do this? Thanks in Advance
