    is custom.css only for default modules?
    13 Posts 4 Posters 5.6k Views 4 Watching
      sdetweil @cluelesscarter
      @cluelesscarter only edit the custom.css
      custom.css is for everything. last stylesheet loaded so it can override anything before it
      remove the .module
      should start with the full module name
        ShuraimHassan @sdetweil
        @sdetweil How can I use Bootstrap on 3rd Party Modules??
          sdetweil @ShuraimHassan
          @ShuraimHassan what is bootstrap?
            @sdetweil What do you mean? Are you not Front end or Full stack Developer??
              @ShuraimHassan no…
              S S 2 Replies Last reply
                @sdetweil Bootstrap is a potent front-end framework used to create modern websites and web apps. It’s open-source and free to use, yet features numerous HTML and CSS templates for UI interface elements such as buttons and forms. Bootstrap also supports JavaScript extensions.
                  @ShuraimHassan but like anything else, u install it
                  https://getbootstrap.com/
                  and for those modules that expose their icon usage, you either change the config or use css to override.
                  each module gets to do its own thing, so u have to fiddle with each one separately…
                  most use font-awesome icons…
                    @ShuraimHassan each module provides a block of html in a div wrapper.
                    the MM runtime positions the block of content where u configured it. (see index.html for the layout)
                    you can also use javascript api calls to create the content that is returned to MM on the getDom() routine.
                    i would say probably >95% of the MM implementations are output only … (as its a ‘mirror’ hanging on the wall, probably 95% of the other 5% are voice based
                    as many are behind shaded glass, the cool color front ends don’t display well, and aren’t particularly helpful to this kind of environment… …
                      @sdetweil could you show me an Example that how Can I do this? Thanks in Advance
                        ShuraimHassan
                        Actually I want to resize of all 3rd party components and Make Responsive of all types of Devices as like Mobile , Tablet , Laptop , PC ETC. . .
                          @ShuraimHassan see this
                          https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1602611995137
                            @ShuraimHassan said in is custom.css only for default modules?:
                            do what? make a module, add a css style to an element?
                            I don’t know ‘responsive’. currently main.css is in pixels for 1920x1080.
                            I have a version I converted to vh/vw.
                            3rd party. mm supplies font_awesome.
                            (see the fonts folder)
                            other than that every module can use whatever they want. no restrictions.
