    NPM start, starts but with blank screen
    21 Posts 2 Posters 7.0k Views 2 Watching
    • N Offline
      natebrown @sdetweil
      So its just finnished updating and ive done npm start and everything seems to show up but it keeps producing the same error over and over again in the log:
      npm start
      magicmirror@2.13.0 start /home/pi/MagicMirror
      [2020-10-18 12:12:18.265] [LOG] Starting MagicMirror: v2.13.0
      [2020-10-18 12:12:18.344] [LOG] Loading config …
      [2020-10-18 12:12:18.373] [LOG] Loading module helpers …
      [2020-10-18 12:12:18.381] [LOG] No helper found for module: alert.
      [2020-10-18 12:12:18.581] [LOG] Initializing new module helper …
      [2020-10-18 12:12:18.585] [LOG] Module helper loaded: updatenotification
      [2020-10-18 12:12:19.726] [LOG] Initializing new module helper …
      [2020-10-18 12:12:19.730] [LOG] Module helper loaded: MMM-Dad-Jokes
      [2020-10-18 12:12:21.332] [LOG] Initializing new module helper …
      [2020-10-18 12:12:21.334] [LOG] Module helper loaded: MMM-Screencast
      [2020-10-18 12:12:21.337] [LOG] No helper found for module: on-this-day.
      [2020-10-18 12:12:22.106] [LOG] Initializing new module helper …
      [2020-10-18 12:12:22.108] [LOG] Module helper loaded: MMM-Remote-Control
      [2020-10-18 12:12:22.182] [LOG] Initializing new module helper …
      [2020-10-18 12:12:22.185] [LOG] Module helper loaded: MMM-learnlanguage
      [2020-10-18 12:12:24.066] [LOG] Initializing new module helper …
      [2020-10-18 12:12:24.068] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
      [2020-10-18 12:12:24.071] [LOG] No helper found for module: clock.
      [2020-10-18 12:12:24.360] [LOG] Initializing new module helper …
      [2020-10-18 12:12:24.363] [LOG] Module helper loaded: calendar
      [2020-10-18 12:12:24.368] [LOG] No helper found for module: compliments.
      [2020-10-18 12:12:24.371] [LOG] No helper found for module: currentweather.
      [2020-10-18 12:12:24.931] [LOG] Initializing new module helper …
      [2020-10-18 12:12:24.934] [LOG] Module helper loaded: email
      [2020-10-18 12:12:24.936] [LOG] No helper found for module: weatherforecast.
      [2020-10-18 12:12:25.039] [LOG] Initializing new module helper …
      [2020-10-18 12:12:25.040] [LOG] Module helper loaded: newsfeed
      [2020-10-18 12:12:25.041] [LOG] All module helpers loaded.
      [2020-10-18 12:12:25.574] [LOG] Starting server on port 8080 …
      [2020-10-18 12:12:25.622] [INFO] You’re using a full whitelist configuration to allow for all IPs
      [2020-10-18 12:12:25.646] [LOG] Server started …
      [2020-10-18 12:12:25.651] [LOG] Connecting socket for: updatenotification
      [2020-10-18 12:12:25.656] [LOG] Connecting socket for: MMM-Dad-Jokes
      [2020-10-18 12:12:25.659] [LOG] MMM-Dad-Jokes helper started
      [2020-10-18 12:12:25.662] [LOG] Connecting socket for: MMM-Screencast
      [2020-10-18 12:12:25.666] [LOG] Connecting socket for: MMM-Remote-Control
      [2020-10-18 12:12:25.668] [LOG] Starting node helper for: MMM-Remote-Control
      [2020-10-18 12:12:25.694] [LOG] Connecting socket for: MMM-learnlanguage
      [2020-10-18 12:12:25.698] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
      [2020-10-18 12:12:25.701] [LOG] Connecting socket for: calendar
      [2020-10-18 12:12:25.702] [LOG] Starting node helper for: calendar
      [2020-10-18 12:12:25.704] [LOG] Connecting socket for: email
      [2020-10-18 12:12:25.705] [LOG] email helper started …
      [2020-10-18 12:12:25.706] [LOG] Connecting socket for: newsfeed
      [2020-10-18 12:12:25.708] [LOG] Starting node helper for: newsfeed
      [2020-10-18 12:12:25.709] [LOG] Sockets connected & modules started …
      [2020-10-18 12:12:27.372] [LOG] Launching application.
      [2020-10-18 12:12:30.530] [ERROR] ERROR! Could not find main module js file for MMM-GoogleAssistant
      [2020-10-18 12:12:43.003] [ERROR] (node:25630) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-10-18 12:12:43.004] [ERROR] (node:25630) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-10-18 12:12:43.033] [LOG] Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [2020-10-18 12:12:43.069] [LOG] listening for emails…
      [2020-10-18 12:12:43.144] [LOG] Create new news fetcher for url: http://rss.nzherald.co.nz/rss/xml/nzhtsrsscid_000000698.xml - Interval: 300000
      [2020-10-18 12:12:43.479] [INFO] Checking git for module: MMM-Dad-Jokes
      [2020-10-18 12:12:43.574] [INFO] Checking git for module: MMM-Screencast
      [2020-10-18 12:12:43.669] [INFO] Checking git for module: on-this-day
      [2020-10-18 12:12:43.738] [INFO] Checking git for module: MMM-Remote-Control
      [2020-10-18 12:12:43.834] [INFO] Checking git for module: MMM-learnlanguage
      [2020-10-18 12:12:43.932] [INFO] Checking git for module: MMM-NowPlayingOnSpotify
      [2020-10-18 12:12:44.047] [INFO] Checking git for module: email
      [2020-10-18 12:12:44.270] [LOG] Refreshed access token because it has expired. Expired at: 12:12:42 now is: 12:12:44
      [2020-10-18 12:12:44.455] [LOG] Email notifier error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      at doWrite (_stream_writable.js:413:19)
      at clearBuffer (_stream_writable.js:543:7)
      at Socket.Writable.uncork (_stream_writable.js:321:7)
      at JSStreamSocket.doWrite (internal/js_stream_socket.js:162:17)
      at JSStream.onwrite (internal/js_stream_socket.js:20:57)
      at Socket.ondata (internal/js_stream_socket.js:64:22)
      at Socket.emit (events.js:200:13)
      at addChunk (_stream_readable.js:294:12)
      at readableAddChunk (_stream_readable.js:275:11)
      at Socket.Readable.push (_stream_readable.js:210:10) {
      source: ‘socket’
      [2020-10-18 12:12:44.509] [ERROR] Whoops! There was an uncaught exception…
      [2020-10-18 12:12:44.516] [ERROR] Error: self signed certificate
      at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
      at TLSSocket.emit (events.js:200:13)
      at TLSSocket._finishInit (_tls_wrap.js:792:8)
      at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12)
      at TCP.onStreamRead (internal/stream_base_commons.js:166:17) {
      code: ‘DEPTH_ZERO_SELF_SIGNED_CERT’,
      source: ‘socket’
      [2020-10-18 12:12:44.535] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-10-18 12:12:44.538] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-10-18 12:12:44.564] [LOG] Email notifier error: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      source: ‘socket’
      [2020-10-18 12:12:44.588] [ERROR] Whoops! There was an uncaught exception…
      [2020-10-18 12:12:44.596] [ERROR] Error: self signed certificate
      source: ‘socket’
        sdetweil @natebrown
        @natebrown
        looks like there are two problems
        MMM-GooogleAssistant.js is not in MagicMirror/modules/MMM-GoogleAssistant folder
        something wrong with your email module
        • N Offline
          natebrown @sdetweil
          What about this part:
          source: ‘socket’
          • N Offline
            natebrown @natebrown
            @natebrown and this one:
              sdetweil @natebrown
              @natebrown said in NPM start, starts but with blank screen:
              DeprecationWarning:
              just a warning that some code (not ours) is using a library call that is going away sometime in the future
              • N Offline
                natebrown @sdetweil
                @sdetweil Thanks, also when i start up my Pi, it shows the “Raspberry Pi OS” Screen and I want it to be just black and how do I speed up autostart (I use sh).
                  sdetweil @natebrown
                  @natebrown if u had used the scripted install, it would have asked if u want to use the node process manager, pm to start at boot
                  u can add it, see command for fixuppm2 here
                  speed up? no idea
                  • N Offline
                    natebrown @sdetweil
                    @sdetweil 1st: Do i execute it in the MagicMirror folder and once its installed what do I do? And will it effect anything on MagicMirror?
                    S 3 Replies Last reply Reply Quote 0
                      sdetweil @natebrown
                      @natebrown the scripts don’t care, they adjust.
                      this script changes the installers/mm.sh
                        sdetweil @natebrown
                        @natebrown once it is installed. on next boot mm will start. if it fails pm2 will restart it. if you ctrl-q, pm2 will restart it.
                        minimize and use the pm2 command to stop, start, restart, view logs…
                        see pm2 --help
