    Black screen with cursor
    12 Posts 2 Posters 4.4k Views 2 Watching
      Clubjack @sdetweil
      I think, i am on Version 2.1.3
      Pm2 logs says : cannot find Module “node_helper”.
      Could that be my problem?
        sdetweil @Clubjack
        @Clubjack show more of log please
          Clubjack @sdetweil
          I got it. Node_helper was replaced and it worked immediately. I’m so glad the work wasn’t in vain.
            sdetweil @Clubjack
            @Clubjack thanks for the feedback, but I’d like to understand what happened. I put a fix I a few releases ago to stop the node_helper.js file from being erased.
              Clubjack @sdetweil
              @sdetweil Maybe my last installed Module “destroyed” the file.
              It was the MMM-WiFiPassword
                sdetweil @Clubjack
                @Clubjack and what did u do to get it back?
                is this the ~/MagicMirror/js/node_helper.js
                or the module node_helper.js
                  Clubjack @sdetweil
                  it was the Module Node_helper.
                  I did this:
                  git checkout modules/node_modules/node_helper/index.js
                    sdetweil @Clubjack
                    @Clubjack ok , you must be running an older version… we moved that in 2.10 to the MagicMirror/js folder to prevent the file being erased by an npm security cleanup feature
                      Clubjack @sdetweil
                      Yes… I think i have 2.3.
                      Should i Update the System?
                        sdetweil @Clubjack
                        @Clubjack well. 2.13 is current. lots of fixes since then. but if it’s working for you…
