    What is wrong with my url?
    16 Posts 2 Posters 5.3k Views 2 Watching
    • E Offline
      EllyJ
      The url scraped from a music player always produces a broken image icon (middle of pic).
      If I input the url in manually and then run the module it will display the image (see comment at the top of the pic).
      If I don’t put in a url I get an outline with no broken image icon.
      I can output the url as a string on the screen (middle of pic and code)
      I can check the url from the music players web interface (bottom of pic).
      Could someone please tell me how to the url into image.src from data[‘albumart’]. This has been bugging me for 2 full days now.
              var data = this.volumioData;
              var item = document.createElement('div');
              var image = document.createElement('img');
              image.src = data['albumart']; //  If I replace this with the url it will display the image
              image.height = 450;
              image.width = 450;
              image.className = 'image';
              item.className = 'mmm-volumio-item';
              item.innerHTML = '<div>' + data['artist'] + ' • ' + data['album'] +
                               '</div>' + '<div>' + data['albumart'] + '</div>';//I put 'albumart' here to prove I had the url
              wrapper.appendChild(item);
              wrapper.appendChild(image);
              return wrapper;
      I am modifying MMM-Volumio to show the Album Covers what is playing. I can’t program in Java but have done a tiny bit in C++,Pascal,Visual Basic and Python. I am sorry if my code is really bad (all 4 lines of it that took me 2 days), it is working except for the url problem. I will also do a better layout when it is working.
        sdetweil @EllyJ
        @EllyJ what format is the this.volumioData? string, json, object?
        • E Offline
          EllyJ @sdetweil
          @sdetweil it json I believe. I’m on a RaspberryPi and the file extension is .js.
          E S 2 Replies Last reply Reply Quote 0
          • E Offline
            EllyJ @EllyJ
            @EllyJ sorry I don’t know about Volumio. At the bottom of the picture is the live data. I just found this but don’t understand what it is getting at.
            If albumart value starts with http, then no further operation is needed and the resulting url will show an albumart
            Otherwise, prepend the string formed by: http:// + IP ADDRESS of Volumio device. Example: http://192.168.1.22/albumart?
              sdetweil @EllyJ
              @EllyJ ok, you need to use
              let data=JSON.parse(this.volumioData)
              to get into object form, then your
              data[‘albumart’] might work
              on my phone
              • E Offline
                EllyJ @sdetweil
                @sdetweil I think I have to add my IP address for the Volumio. When I was looking to see if Volumio is json I stumbled on this on their website. Can I += strings?
                  sdetweil @EllyJ
                  @EllyJ I’m not sure
                    sdetweil @EllyJ
                    @EllyJ this.volumioData should be the response from the server
                    • E Offline
                      EllyJ @sdetweil
                      @sdetweil it is. If you look at the url it gives to the album art it does not start with http://192.168… so I just need to add that I believe. I stumbled on that info by mistake thanks to you. I will try and get that working now.
                      • E Offline
                        EllyJ
                        Ok it works :grinning_face_with_smiling_eyes: The problem was I needed to add the Raspberry Pi’ address before the album art url. Thank you very much @sdetweil for asking me a question that led to that info.working.png
                        As you can see it needs to be shifted about a little to look good.
                                var amendUrl = "";
                                if (data['service'] == "mpd") {
                                    amendUrl = this.config.volumioUrl + data['albumart'];} // if local playback use volumio url +  albumart url
                                else{
                                    amendUrl = data['albumart'];}                   // else if web radio just albumart url
                                image.src = amendUrl;                               // set url to the image
                                image.height = 600;
                                                 '</div>' + '<div>' + data['album'] + '</div>';//I put 'albumart' here to prove I had the url
                                wrapper.appendChild(item);                          // display artist, album and title info
                                wrapper.appendChild(image);                         // display album artwork
                                return wrapper;
                        Here is my messy code, I don’t really do any coding so I was winging it.
                          sdetweil @EllyJ
                          @EllyJ did u download the image to the mm server?
                          • E Offline
                            EllyJ
                            Sam it was from the NAS that has all my music. I have three Pi’s, a NAS, a Volumio music player and now a Magic Mirror. The Mirror Pi got the image url from Volumio Pi and then got the image from the NAS Pi. Lots of Pi! I have fiddled with the layout and it is presentable but not finished. Almost.png
                            • E Offline
                              EllyJ
                              I have finished this now and tidied the code up (I hope it is up to standard). Below is a screenshot of the layout I went with, the changes I made to the .js file and the whole CSS file. I would like to give a lot of credit to @trgraglia who created MMM-Volumio and those who modified it before me. I hope there is enough info here for anyone who wants to create there own Volumio viewer. The position in the MagicMirror config file was top_bar.
                              File: modules/MMM-Volumio/MMM-Volumio.js (the bit I changed at the end)
                                      var amendUrl = "";
                                      var artists = document.createElement('div');
                                          amendUrl = this.config.volumioUrl + data['albumart'];} // if local playback put volumio url +  albumart url
                                      else{
                                      artists.className = 'text';
                                      artists.innerHTML = '<div>' + '<br />' + data['artist'] + '<br />';
                                      wrapper.appendChild(artists);
                                      item.className = 'smalltext' //'mmm-volumio-item';
                                      item.innerHTML = '<div>' + data['album'] + '<div>' + '</div>' + data['title'] + '</div>';//I put 'albumart' here to prove I had the url
                                      return wrapper;
                              File: modules/MMM-Volumio/MMM-Volumio.css
                              .region.fullscreen.below {
                                  position: absolute;
                                  height:   100%
                                  width:    100%
                              .mmm-volumio-item {
                                  text-align:  center;
                                  line-height: 40pt;
                                  font-size:   95%;
                                  color:       LightGrey;
                                  position: absolute;
                                  height:   100%;
                                  width:    100%;
                                  border-right:  24px;
                              .image
                                  position:    Fixed;
                                  bottom:      0px;
                                  left:        0px;
                                  width:   100%;
                              .text
                                  text-align:  center;
                                  line-height: 60pt;
                                  font-size:   160%;
                                  color:       DimGrey;
                              .smalltext
                                  text-align:  center;
                                  line-height: 40pt;
                                  font-size:   100%;
                                  color:       Grey;
                                sdetweil @EllyJ
                                @EllyJ did u make a fork of the original and upload your changes back , so others can get your version?
                                fork original
                                download your forked copy
                                make changes
                                git add/commit/push your chnages back to your fork…
                                • E Offline
                                  EllyJ
                                  @sdetweil I did not. I do not know how to or what a fork is. I am not sure if it is good enough, it looks like it is commercial quality and it works but I just kind of forced it to do what I wanted. I don’t know JavaScript or CSS, I just googled, copied, tried and guessed until it worked. Perhaps someone could try it out and then fork it if it works for them.
                                    sdetweil @EllyJ
                                    @EllyJ go to github on the original project
                                    push the fork button top right. now u have a copy, and ‘could’ submit changes back to the author as ‘pull request’, pull from your repo back to his.
                                    now, rename your current module folder
                                    and then git clone your fork, and do npm install if the original asked for it
                                    now, copy the changed files from the renamed folder to the new one.
                                    if all is good
                                    then we can work on getting the changes pushed up to your fork
