    MagicMirrorOS starts up with blank screen
    19 Posts 4 Posters 8.5k Views 4 Watching
      barenakedchicken
      I have been at this for months. No script will run at all. I think it has something to do with my internet. But I am at my whits end. Scripts will not work no matter what tutorial I try to use. I have tried this script a couple times. Literally nothing is working. And I have reached out to buy an SD Card that someone has already created with Magic Mirror working and configured, but no one seems to want to sell one.
        sdetweil @barenakedchicken
        @barenakedchicken where r u located?
        B 1 Reply Last reply
          barenakedchicken @sdetweil
          Ann Arbor, mi
            @barenakedchicken and u have bad internet there? I am from farmington, a mere 30 miles east of you.
            UofM should drag the best internet to your location.
            everything MagicMirror requires internet
              barenakedchicken
              You’d think, but I live on a farm. As a network engineer, I have exhausted all possibilities of any kind of broadband and fibre service here. We have satellite on one side of the property and LTE on the other side. Satellite just sucks, and the LTE is at 1 bar.
                @barenakedchicken satallite does suck for sure. suffered thru HughesNet for a year.
                I can get u a configured SD Card but without network, your gonna be in the same boat, trying to add modules or get info downloaded.
                  Are there no offline modules I could use? I’m literally trying to create a local bulletin board to put out in the barns, not exactly a mirror
                  S 2 Replies Last reply
                    @barenakedchicken i have no idea… see the chat i started with you
                      @barenakedchicken you could write a module that reads from the local SD disk space… course without network support you will have to find a way to update… maybe usb stick as disk,
                      • E
                        eracerhead
                        I tried flashing magicmirroros. I managed to get ssh running and the wpa_supplicant to get on the wifi. All I get on the console is a blank screen.
                        As I was unable to get anything to work, I tried updating using sdetweil/MagicMirror_scripts but it says the pi zero is not supported.
                        I’m completely lost now.
                          sdetweil @eracerhead
                          @eracerhead said in MagicMirrorOS starts up with blank screen:
                          u just reply yes, it keeps going… MM does 'support’s Pi3 and 4 now… but I make it work other places
                          u don’t need MM OS… just flash Raspi OS Buster, run my script…
                            Dimasua
                            @sdetweil Thank you for sharing your scripts. Will try today.
                            Do you know if there a way to provide the Raspi OS with the WiFi SSID and password without logging into Raspi desktop environment? Like in a text file or so?
                              sdetweil @Dimasua
                              @Dimasua Google search yielded this
                              https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md
                              D 1 Reply Last reply
                                Dimasua @sdetweil
                                @sdetweil Thank you. I was looking for a solution to provide SSID and password upfront, so no interactions are needed and Raspi can connect to your WiFi right out from the start.
                                  sdetweil @Dimasua
                                  @Dimasua nothing built in. U have to at least edit or creste a file…u could do that after u flash the SD card. Before booting it
