    MMM-News
    55 Posts 15 Posters 51.7k Views 14 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      @sdetweil I don’t see that as an option in the config…
        sdetweil @swvalenti
        @swvalenti edit line 48 of node_helper.js
        change
            this.scanInterval = 1000*60*10
        to this
            this.scanInterval = 1000*60*15
          A Former User @sdetweil
          @sdetweil yes, it’s new they have limited request. So I will add new part of code for define interval, quickly
            A Former User
            Hi, I have upgraded to v2.1.2 with personal fetch interval.
            By default i put 30 min in default config
              @Bugsounet thank you very much
                @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
                  		module: "MMM-News",
                  		position: "bottom_bar",
                    		apiKey : "XXXXXXXXX",
                    		type: "horizontal",
                    		query : [
                        	sources: "fox-news, fox-sports",
                        country: "us",
                        className: "redTitle",
                	touchable: false,
                	scanInterval: 1000*60*15
                  Not sure what it means but says initialized with 10 query
                  /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                  1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
                  1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
                  1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                  1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                  1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                  1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
                  1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
                  1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                  1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                  1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
                  1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
                  1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
                  1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
                  1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                  1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
                    A Former User
                    limited to 100 query by day and 50 query for 12 hours
                    It’s not me who have set this limit but it’s news api
                    and sorry, i don’t work in news api too ! :)
                    so now just a little calc…
                    you have 10 query and refresh is set to 15m
                    for one query for one hour (every 15min) => 4 query
                    for 10 query for one hour (every 15 min) => 4*10 = 40 query
                    in 12 hours with one query => 12 * 4 = 48 query / 50 max
                    in 12 hours with 10 query => 12* 40 = 480 query / 50 max
                    in 24 hours with one query => 24 * 4 => 96 query / 100 Max
                    in 24 hours with 10 query => 24*40 => 960 query / 100 max
                    That why you have this error… and I just calc the number of query
                    –> result: it take 9 query (take a lot of resource)
                       country: "us",
                    –> result: it take just one query
                    Note: personnaly, i use only redTitle of my country
                    Note 2: i will add soon a counter for calc if number of query is correct
                      @Bugsounet Ok thanks for the detailed explanation. Here is my config now so hopefully this should resolve it.
                        		module: "MMM-News",
                          		apiKey : "XXXXXXXXXXXXXXXXXXX",
                          		type: "horizontal",
                          		query : [
                              country: "us",
                      	touchable: false,
                      	scanInterval: 1000*60*30
                        A Former User
                        perfect, it should work perfectly now
                        • 4 / 6
