MMM-ResRobot - Public transport information for Sweden
Could you please post your config? It seems that MMM-ResRobot is never executed. -
Here is my config:
module: “MMM-ResRobot”,
position: “left”,
header: “Departures”,
from: “740059355”, // ResRobot Station ID (or a comma-separated string of IDs)
to: “740059412”, // ResRobot Station ID of destination (or a comma-separated string of IDs)
maximumEntries: 6, // Number of departures to show on screen
truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation
apiKey: “a6e181d4-3065-4214-a30b-780163xxxxxx” // Your ResRobot apiKey
I copied your config and eslint complained about the quote characters. Make sure that you use the standard " character, not “ or ”.
Using your config with my apiKey works as it should.
/j -
@Notumlord and @Klzow, I think I have found the issue. When the ResRobot API call failed for some reason the next update was never scheduled resulting in a “freeze”. I have pushed an update to github which schedules an update when the API call fails. (In my case the ResRobot site returned a “site unavailable” error every now and then which froze the module) Sorry for the bug!
@Alvinger Perfect! Thank you very much! Have been running it for 48 hours without any problem now.
New version out with one minor change: transportation type icons are now displayed (to the left of the linenumber). All rail-bound types are displayed as trains (fa-train), all buses are displayed as bus (fa-bus) and all waterborne transportation is displayed as ship (fa-ship).
Thanks @Alvinger for an awesome module! However, I have a problem when I add more than one destination (to:). Displays only the result of the destination that appears first.
Here is my config.js:
{ module: "MMM-ResRobot", position: "left", header: "Departures from Skanör C", config: { from: "740000950", // ResRobot Station ID (or a comma-separated string of IDs) to: "740000003,740001586", // ResRobot Station ID of destination (or a comma-separated string of IDs) maximumEntries: 6, // Number of departures to show on screen truncateAfter: 5, // A value > 0 will truncate direction name at first space after characters. 0 = no truncation apiKey: ”[My API-key]" // Your ResRobot apiKey } },
you need to specify a station id in “from” as well. “from” is used to find the station’s departures, “to” is used to differentiate between destinations going from the “from” station.Change “from” to ‘from: “740000950,740000950”’ to make it work as you want.
Of course! Thank you very much @Alvinger!
Hi!
I have a question /idea /request.Would it be possible to set a limit in minutes in which the module won’t show departures before that limit?
For example I have a 15 min walk to bus/subway and during rush hour in Stockholm lots of departures are happening every minute. To be able to plan ahead and see when the bus is leaving I need to show many departures on the mirror to see that far ahead in time. Would it be possible to set a limit to not show departures happening earlier then 15 min ahead since it would not be necessary to know that the subway is leaving in 1 min when I can’t get her there in time to catch it? This would clean up the mirror and save some space on the screen.
