    Custom Commands in @MMM-Remote-Control
    5 Posts 3 Posters 1.8k Views 3 Watching
    • G Offline
      gkchimz
      I am using a raspberry pi 4. I have a radio frequency transmitter attached to one of my GPIO pins and I am using running a python script through the terminal to send a command that will turn on/off and change the colour of my led lights. (See link below). I have said these files in my MagicMirror folder.
      Is it possible to use custom commands to do this? If so can you help me understand how. Attached are the shell files that are executable and work( when i double click the files in desktop mode - the lights change). How do i link this to MMM-Remote-Control or do the same action in MMM-Remote-Control?
      Config.js
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", 	// Address to listen on, can be:
      	//address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: [], 	// Set [] to allow all IP addresses
      	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses														// or add a specific IPv4 of 192.168.1.5 :
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      		    	module: 'MMM-Remote-Control',
      		     	position: 'bottom_right',
      				customCommand: {},  // Optional, See "Using Custom Commands" below
      				showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      				// uncomment any of the lines below if you're gonna use it
      				// customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      				// apiKey: "",         // Optional, See API/README.md for details
      			customCommand: {
      				monitorOnCommand: 'cd ./MagicMirror python3 send.py -p 396 -t 1 11717633',
        			module: "MMM-Remote-Control-Repository",
      Shell Script
      cd ./MagicMirror
      send.py
      #!/usr/bin/env python3
      import argparse
      import logging
      from rpi_rf import RFDevice
      logging.basicConfig(level=logging.INFO, datefmt='%Y-%m-%d %H:%M:%S',
                          format='%(asctime)-15s - [%(levelname)s] %(module)s: %(message)s',)
      parser = argparse.ArgumentParser(description='Sends a decimal code via a 433/315MHz GPIO device')
      parser.add_argument('code', metavar='CODE', type=int,
                          help="Decimal code to send")
      parser.add_argument('-g', dest='gpio', type=int, default=17,
                          help="GPIO pin (Default: 17)")
      parser.add_argument('-p', dest='pulselength', type=int, default=None,
                          help="Pulselength (Default: 350)")
      parser.add_argument('-t', dest='protocol', type=int, default=None,
                          help="Protocol (Default: 1)")
      parser.add_argument('-l', dest='length', type=int, default=None,
                          help="Codelength (Default: 24)")
      parser.add_argument('-r', dest='repeat', type=int, default=10,
                          help="Repeat cycles (Default: 10)")
      args = parser.parse_args()
      rfdevice = RFDevice(args.gpio)
      rfdevice.enable_tx()
      rfdevice.tx_repeat = args.repeat
      if args.protocol:
          protocol = args.protocol
      else:
          protocol = "default"
      if args.pulselength:
          pulselength = args.pulselength
      else:
          pulselength = "default"
      if args.length:
          length = args.length
      else:
          length = "default"
      logging.info(str(args.code) +
                   " [protocol: " + str(protocol) +
                   ", pulselength: " + str(pulselength) +
                   ", length: " + str(length) +
                   ", repeat: " + str(rfdevice.tx_repeat) + "]")
      rfdevice.tx_code(args.code, args.protocol, args.pulselength, args.length)
      rfdevice.cleanup()
      apt-get install python3-pip
      pip3 install rpi-rf
      https://github.com/milaq/rpi-rf/tree/master/scripts
        sdetweil @gkchimz
        @gkchimz you use a curl command to send a request to the remote control api url
        • G Offline
          gkchimz
          @sdetweil - thank you very much for your prompt response. I have not learned about curl commands yet ( although i know i have copied and pasted one during installation of modules.
          Are you able to point me towards an example or a good page that i may be able to lean the relevant things quickly please.
            sdetweil @gkchimz
            @gkchimz Google is your friend
            Also every command has help
            curl --help
            • E Offline
              ezeholz
              Hello! Ezequiel here. customCommands should be inside the config of the Remote Control. You can raise a question in the issue page for further instructions. Cheers :D
