    snowboy: Device or resourse busy
    12 Posts 3 Posters 3.5k Views 3 Watching
      sdetweil @banbutcher
      @banbutcher no… i see it end unexpectedly more than hang, 999 times :1
        banbutcher
        and you can tell from that output that it hung?
        I think its when i refresh MM, it doesnt close snowboy properly so when MM refreshes snowboy is open already and hangs?
        EDIT* (I tested the theory and if i refresh my MM then snowboy goes into that error loop.)
        would that make sense?
          @banbutcher yes, seems logical. Another platform cleans up on refresh.
            banbutcher
            could there be a way to shut it properly if the mirror is refreshed?
              @banbutcher yes, but coding required
                banbutcher
                @sdetweil as always thanks for your help!
                i think i need to bring in the expert: @Bugsounet have you any thoughts?
                  A Former User @banbutcher
                  @banbutcher don’t know really, in all case it will be restart
                  I have coded this code ‘on error… Retry and make a loop (is needed)’
                  And I code ‘stop snowboy every 12h snowboy and restart it (and verify any error)’
                  So the code is normally controlled by the library
