    Ecobee
    50 Posts 19 Posters 37.6k Views 20 Watching
      parnic @colel83
      @colel83 Sure, it would be pretty simple to have a configurable to suppress certain attributes like humidity. It would be most helpful for me if you would create issues on the GitHub page to help track that.
      I would also love to be able to set the temperature from the module for touchscreens, but that needs a lot more work since the core of how the module is communicating with Ecobee needs to change to enable that.
        colel83
        Awesome!! I looked all over on your github repository for a place to create an issue but I just could not find a way. A google search brought me here and since you had commented recently I thought I would just post here. I’ll head back over to the repository and see if I can find where to submit an issue. Thanks!
          parnic @colel83
          @colel83 My fault, looks like issues were disabled on the repository I cloned from. I enabled them now! https://github.com/parnic/MMM-Ecobee/issues
          • F Offline
            ftap
            This would be awesome!
            Unfortuntely, I can’t even load the MyApps section of the site. Does nothing to for me :(
              parnic @ftap
              @ftap Not real sure how to help you on that one. It’s currently working for me. Either way, it’s Ecobee’s site, so you could try contacting their support maybe. Or a different browser perhaps.
                rmonkey
                I’m a little dense today – where do I find the API code to authorize?
                  parnic @rmonkey
                  @rmonkey It should all be explained on the screen when attempting to connect. There are steps listed along with an API code to use.
                    rmonkey
                    I’m afraid I’m stumped – I just have a spinning circle where the module loads. No instructions on the MM screen. I checked with “ls -l” and the user is set as the owner.
                      parnic @rmonkey
                      @rmonkey Check your MM process log or browser console log. It should explain why it’s not able to load.
                        rmonkey
                        All good – I rebooted instead of reload and got the info to link.
                        Thanks for the great module and your help!
                        • bugsounetB bugsounet referenced this topic on
                        • 3 / 3
