    Ecobee
    50 Posts 19 Posters 43.3k Views 20 Watching
    • F Offline
      fabbr @stephenmelody
      @stephenmelody The way ecobee API works is: if you don’t check the status for a period of time it will make you reauthorize. Let’s say: You turn your mirror off for a couple of days, when you turn on you most likely will have to reauthorize. I don’t see a way around that :(
      And I will be working on the changes this week and post a branch for the new code here for us to test.
        stephenmelody
        OK, it wasn’t a complaint, just some feedback in case it helps. I have my mirror set up so that only the screen turns off when no one is home, but the pi keeps on trucking in the background. I’d have to look and see what happened, but I got it reauthorised and I’ll see if it does it again.
        Looking forward to new code!!!
        • F Offline
          @stephenmelody hahah I took it as feedback :) I need a lot of it to make this as usable as possible. keep them coming
            JRCelis
            The module is working fine. Thanks! Is there any way to change the output temperature to Celsius instead of Fahrenheit?
            • citizendevpiC Offline
              citizendevpi
              first off thanks I really enjoy the module!! great work! I do not have any colors on my dashboard at all and reading the thread I see that when my furnace is running the flame should be red?
              • richland007R Offline
                richland007
                @fabbr Thank you for the Ecobee Module.
                I really like it and it has been working fine for me… however i am running pm2 and watchdog and for some reason the mirror is restarting quite often and every time it wants to reauthorize with Ecobee api why is that and how can i minimize it… it happens like 5 times a day or more …annoying kinda thing.
                Any thoughts??
                Denis
                  richland007
                  Any thoughts on the above issue??
                    Arkitct
                    This is awesome @fabbr , many thanks!
                    Any word on doing a colored: true option? I’m just starting down the road of MM, so I may peak into the code to see if it’s something I can tackle.
                    • L Offline
                      LordBane
                      I just got started with Magic Mirror and found this module. It’s awesome! I was so happy to find it. My fear is that you’ve stopped working on it. I’m really hoping you for the celsius conversion… Though you’d think that Celsius would be the default from the Ecobee API. Ecobee is a Canadian company!
                        majik655
                        I fear it has been a while too for this module…
                        The module is working great!
                        But is there a way to only show the thermostat and not the sensors?
                        • H Offline
                          hisstory2002 @LordBane
                          @LordBane Good day all, really love this module great work. i just found this and noticed that it was in fahrenheit but as a canadian i would like it to be in celsius. so i look at the code and found the lines that need updating for it to display in celsius.
                          to do this you will need to edit the file MMM-Ecobee.js (Location = MagicMirror/modules/MMM-Ecobee/)
                          update line 58 to be “var desiredHeat = Math.round(((thermo.runtime.desiredHeat / 10)-32)*5/9);”
                          update line 59 to be “var desiredCool = Math.round(((thermo.runtime.desiredCool / 10)-32)*5/9);”
                          update line 106 to be “currentTemp.innerHTML = Math.round(((device.capability[0].value / 10)-32)*5/9);”
                          once that is done refresh the Mirror and the number will be updated.
                          Please let me know if this cause any problems for anyone.
                          Thank you
                            parnic
                            Hello all,
                            I am maintaining a fork of this module that works with the new API changes coming from Ecobee very soon as well as showing the temperatures in Celsius if your thermostat is set to celsius. I also fixed the module sometimes being far too aggressive on hitting the Ecobee api, re-requesting authorization, etc. I have a few other things I’m adding soon such as a config property for showing sensors or not as well as an option to display colors for those of us using this on a monitor without a mirror in front.
                            Any and all feedback is appreciated! https://github.com/parnic/MMM-Ecobee
                              colel83
                              Thank you for the updates to keep the module working with the new api changes! I am wondering though, is there anyway you could add the ability to hide the humidity and the set temperature in the thermostat readout? I would like to just have the actual thermostat display the current temp like the sensors do. On the original module I just commented out certain lines to make them disappear but the new code doesn’t look the same. Thanks again.
                                parnic @colel83
                                @colel83 Sure, it would be pretty simple to have a configurable to suppress certain attributes like humidity. It would be most helpful for me if you would create issues on the GitHub page to help track that.
                                I would also love to be able to set the temperature from the module for touchscreens, but that needs a lot more work since the core of how the module is communicating with Ecobee needs to change to enable that.
                                  colel83
                                  Awesome!! I looked all over on your github repository for a place to create an issue but I just could not find a way. A google search brought me here and since you had commented recently I thought I would just post here. I’ll head back over to the repository and see if I can find where to submit an issue. Thanks!
                                    parnic @colel83
                                    @colel83 My fault, looks like issues were disabled on the repository I cloned from. I enabled them now! https://github.com/parnic/MMM-Ecobee/issues
                                    • F Offline
                                      ftap
                                      This would be awesome!
                                      Unfortuntely, I can’t even load the MyApps section of the site. Does nothing to for me :(
                                        parnic @ftap
                                        @ftap Not real sure how to help you on that one. It’s currently working for me. Either way, it’s Ecobee’s site, so you could try contacting their support maybe. Or a different browser perhaps.
                                          rmonkey
                                          I’m a little dense today – where do I find the API code to authorize?
                                            parnic @rmonkey
                                            @rmonkey It should all be explained on the screen when attempting to connect. There are steps listed along with an API code to use.
                                            • 2 / 3
