    Ecobee
    50 Posts 19 Posters 41.6k Views 20 Watching
      stephenmelody
      Ok, I can do that, although you might regret it!!
      Some questions that might turn into requests… but these all seem to be minor tweaks
      Does the heat symbol change colour depending on whether the system is heating or cooling, like it does on the app? (orange flame for heating, blue snowflake for cooling). In the example below, it’s currently 68, targeting 71. The app shows the flame in orange, that would be nice to quickly visualise if the system is running.
      Can the order in which the sensors are presented be set? For example, I’d like my Thermostat to be at the top, not the bottom
      It would be nice to be able to toggle what you see, for example, on my thermostat, I’m not too bothered about the humidity, so it would be nice to toggle that off - that would make the module smaller on my screen.
      Great work by the way, I’m happy this is a new module, I’ve been hoping for this one for a while!!!
      Here’s what I see
      • F Offline
        fabbr @stephenmelody
        @stephenmelody said in Ecobee:
        Currently No. I could add that tho. Currently the way you can check if the system is running or not is by checking the icon of the thermostat. It will change depending on the running status. I did that because a lot of people don’t like to have colors on their Mirrors. However, if you think this would make it better, elaborate on the different status and what should be displayed and I will work on having that as an option!
        If you haven’t notice, when there’s motion the icon of the sensor also changes :)
        Not currently. The results of the API will always give the Thermostat as the last “device” I can have that as an option also. Any other order change that you think should happen?
        I will add that an option, keep in mind that you won’t save any space on the module, you only will see less information.
        Here’s what I see
        I am happy that it’s working! I have spend countless hours working on it.
          stephenmelody
          Checking the icon of the thermostat - what are the options here? mine says ON, but the system is in idle (neither heating nor cooling). Is that what you meant? I have noticed the motion icon - I like that!
          If you could toggle the displayed info, wouldn’t all the icons shift over to the right, if there was less on the line?
          Elaboration, I think these would be the options, to be honest, I think it would just be System Heat Mode and System Cool Mode that I would be intereted in, I don’t have the capabilities for the other icons. I know a number of modules that I have allow for the toggle of colour on / off:
          alt text
          • F Offline
            Right now it will show if the Thermostat is set to a mode (ON) or off (OFF)
            First image is OFF, Second is set to AUTO (69-64):
            Screen_Shot_2018_04_06_at_10_38_16_AM
            Screen_Shot_2018_04_06_at_10_41_20_AM
            That being said, to show when it’s ACTUALLY running I need to figure what is the best way. (if that is important)
            Not the way the I have the code running right now :(
            So you want to see the colors in the module? or see them when the machine is running only?
            Thanks for the feedback. I can’t way to go back to work on it :)
              stephenmelody
              OK, what would be “important” to me, would be to show what the system is doing:
              So if the AC is running, then a Blue Snowflake, if the Heating is running, an Orange Flame, it would just need to be one of them, not both, as per the app example. If nothing is actually running, then white would be fine.
              For example:
              Heating:
              alt text
              Cooling:
              alt text
              • F Offline
                @stephenmelody GOT it! I will add to the module! Let me know if you have other changes you want and how the module is working for you!
                  stephenmelody
                  let’s start with that and Celsius. Let me know when it’s ready and I’ll test it for you!
                  Thanks, this module is going to be great!!
                    majik655
                    Installed module last night … Great work! and Thank you again for creating this module!
                    While installing I now understand why the CODE from ecobee module may have been missed by others.
                    I was expecting to see the code and still took a minute or second look to see the code at the very bottom of the last sentence in the instructions on screen. If this CODE could maybe be larger or maybe a color that stands out?? Might help a little .
                    I too would like to choose which sensors are shown…or show them in a specific order.
                    One more thing that I would love would be making the module smaller.
                    I am still learning all of this and I played with Custom.css but of course the module will start to cut the wording and sensors off from visually being seen from the bottom up.
                    I will play more with it tonight… but this is awesome already! Thank you!
                      stephenmelody @fabbr
                      @fabbr any updates?
                      I’ve had the module running for a while now, but I’ve been away. When I got back, it had forgotten the ecobee module was authorised so I had to do that again.
                      • F Offline
                        @stephenmelody The way ecobee API works is: if you don’t check the status for a period of time it will make you reauthorize. Let’s say: You turn your mirror off for a couple of days, when you turn on you most likely will have to reauthorize. I don’t see a way around that :(
                        And I will be working on the changes this week and post a branch for the new code here for us to test.
                          stephenmelody
                          OK, it wasn’t a complaint, just some feedback in case it helps. I have my mirror set up so that only the screen turns off when no one is home, but the pi keeps on trucking in the background. I’d have to look and see what happened, but I got it reauthorised and I’ll see if it does it again.
                          Looking forward to new code!!!
                          • F Offline
                            @stephenmelody hahah I took it as feedback :) I need a lot of it to make this as usable as possible. keep them coming
                              JRCelis
                              The module is working fine. Thanks! Is there any way to change the output temperature to Celsius instead of Fahrenheit?
                              • citizendevpiC Offline
                                citizendevpi
                                first off thanks I really enjoy the module!! great work! I do not have any colors on my dashboard at all and reading the thread I see that when my furnace is running the flame should be red?
                                • richland007R Offline
                                  richland007
                                  @fabbr Thank you for the Ecobee Module.
                                  I really like it and it has been working fine for me… however i am running pm2 and watchdog and for some reason the mirror is restarting quite often and every time it wants to reauthorize with Ecobee api why is that and how can i minimize it… it happens like 5 times a day or more …annoying kinda thing.
                                  Any thoughts??
                                  Denis
                                    richland007
                                    Any thoughts on the above issue??
                                      Arkitct
                                      This is awesome @fabbr , many thanks!
                                      Any word on doing a colored: true option? I’m just starting down the road of MM, so I may peak into the code to see if it’s something I can tackle.
                                      • L Offline
                                        LordBane
                                        I just got started with Magic Mirror and found this module. It’s awesome! I was so happy to find it. My fear is that you’ve stopped working on it. I’m really hoping you for the celsius conversion… Though you’d think that Celsius would be the default from the Ecobee API. Ecobee is a Canadian company!
                                          majik655
                                          I fear it has been a while too for this module…
                                          The module is working great!
                                          But is there a way to only show the thermostat and not the sensors?
                                          • H Offline
                                            hisstory2002 @LordBane
                                            @LordBane Good day all, really love this module great work. i just found this and noticed that it was in fahrenheit but as a canadian i would like it to be in celsius. so i look at the code and found the lines that need updating for it to display in celsius.
                                            to do this you will need to edit the file MMM-Ecobee.js (Location = MagicMirror/modules/MMM-Ecobee/)
                                            update line 58 to be “var desiredHeat = Math.round(((thermo.runtime.desiredHeat / 10)-32)*5/9);”
                                            update line 59 to be “var desiredCool = Math.round(((thermo.runtime.desiredCool / 10)-32)*5/9);”
                                            update line 106 to be “currentTemp.innerHTML = Math.round(((device.capability[0].value / 10)-32)*5/9);”
                                            once that is done refresh the Mirror and the number will be updated.
                                            Please let me know if this cause any problems for anyone.
                                            Thank you
                                            • 2 / 3
