    Clock and current weather horizontally
    8 Posts 3 Posters 1.9k Views 3 Watching
      JasonInOttawa
      @ashishtank I believe you’re showing a clock followed by a calendar. If so, yes, that’s what I’d like, except with a clock and current weather. Thanks very much for your reply.
      J A 2 Replies Last reply Reply Quote 0
        JasonInOttawa @JasonInOttawa
        This seems to work
        .currentweather {
          display:inline-block;
          margin: 2px;
          zoom:60%;
        .clock {
          margin: 2px;
          ashishtank Module Developer @JasonInOttawa
          @JasonInOttawa yes, Indeed I was only giving example to understand the requirement. you can do it by using custom.css file. Add below code to show clock and current weather side by side.
          .clock
          	float: left;
          .currentweather
          	float: left;
          	padding-left: 20px; //Adjust this for left spacing between both modules
          below should be output.
            @JasonInOttawa yes there are multiple ways to achieve the same :) We both posted reply at same time !
              JasonInOttawa @ashishtank
              @ashishtank Thanks again! I did notice one difference: the inline-block keeps the bottoms lined up
              and the float puts the second element a bit higher:
              It all depends on which effect you prefer.
                @JasonInOttawa May be float is doing this because you are not showing week text as header ? In my screenshot they are aligned on top. Any ways both are on user choice ! :)
