    calendar plugin: all items one day ahead
    6 Posts 3 Posters 1.5k Views 4 Watching
    • K Offline
      Kugelfang
      For the record: I rolled back the default calendar plugin to the previous release (April) an the problem is solved. There seems to be something wrong with the latest release
        anderios Banned
        what about in 2020?
          sdetweil @anderios
          @anderios download the develop branch which has a bunch of calendar fixes. see the office 365 topic at the top of the troubleshooting section
            anderios Banned
            Something has been done wrong from your side, I will not be able to check it from my sources. You can try the following thing. Uninstall the plugin completely and then download it again. It should work this time. If the mistake is there again, then it must be something incorrect with the code. And you will not be able to amend anything on your own. You should report the problem to developers.
              sdetweil @anderios
              @anderios i have worked for the last 3 months to get the calendar module working properly. I think I have solved all the reported problems.
              the fixes will be released on Jan 1, but in the meantime you can use the develop branch of the repo which has all the accepted fixes since last release
