    Display waste bins in color
    52 Posts 3 Posters 26.4k Views 3 Watching
      sdetweil @kusselin
      @kusselin new release available
      • kusselinK
        kusselin
        Ok i see…thanks snd now the update how is standing in the update manual here…right
          sdetweil @kusselin
          @kusselin eh? not sure what u said. run my upgrade script
          see
          • kusselinK
            kusselin
            o.k thanks
            • kusselinK
              kusselin
              here my update installation:
              pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              No LSB modules are available.
              doing test run = false
              saving custom.css
              upgrading from version 2.13.0 to 2.14.0
              fetching latest revisions
              From https://github.com/MichMich/MagicMirror
                 3dbe8bfb..10dc315f  master     -> origin/master
               * [new tag]           V2.2.1     -> V2.2.1
               * [new tag]           v.2.1.3    -> v.2.1.3
               * [new tag]           v2.0.0     -> v2.0.0
               * [new tag]           v2.0.1     -> v2.0.1
               * [new tag]           v2.0.2     -> v2.0.2
               * [new tag]           v2.0.3     -> v2.0.3
               * [new tag]           v2.0.4     -> v2.0.4
               * [new tag]           v2.0.5     -> v2.0.5
               * [new tag]           v2.1.0     -> v2.1.0
               * [new tag]           v2.1.1     -> v2.1.1
               * [new tag]           v2.1.2     -> v2.1.2
               * [new tag]           v2.10.0    -> v2.10.0
               * [new tag]           v2.10.1    -> v2.10.1
               * [new tag]           v2.11.0    -> v2.11.0
               * [new tag]           v2.12.0    -> v2.12.0
               * [new tag]           v2.14.0    -> v2.14.0
               * [new tag]           v2.2.0     -> v2.2.0
               * [new tag]           v2.2.2     -> v2.2.2
               * [new tag]           v2.3.0     -> v2.3.0
               * [new tag]           v2.3.1     -> v2.3.1
               * [new tag]           v2.4.0     -> v2.4.0
               * [new tag]           v2.4.1     -> v2.4.1
               * [new tag]           v2.5.0     -> v2.5.0
               * [new tag]           v2.6.0     -> v2.6.0
               * [new tag]           v2.7.0     -> v2.7.0
               * [new tag]           v2.7.1     -> v2.7.1
               * [new tag]           v2.8.0     -> v2.8.0
               * [new tag]           v2.9.0     -> v2.9.0
              > core-js@3.7.0 postinstall /home/pi/MagicMirror/node_modules/core-js
              > node -e "try{require('./postinstall')}catch(e){}"
              Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
              The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
              > https://opencollective.com/core-js
              > https://www.patreon.com/zloirock
              Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
              > electron@8.5.3 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              > magicmirror@2.14.0 install /home/pi/MagicMirror
              " && cd vendor && npm install --loglevel=error
              > @fortawesome/fontawesome-free@5.15.1 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
              > node attribution.js
              Font Awesome Free 5.15.1 by @fontawesome - https://fontawesome.com
              License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
              updated 3 packages and audited 24 packages in 18.623s
              1 package is looking for funding
                run `npm fund` for details
              found 0 vulnerabilities
              > magicmirror@2.14.0 postinstall /home/pi/MagicMirror
              > npm run install-fonts && echo "MagicMirror installation finished successfully!
              > magicmirror@2.14.0 install-fonts /home/pi/MagicMirror
              > echo "Installing fonts ...
              " && cd fonts && npm install --loglevel=error
              audited 1 package in 3.134s
              added 55 packages from 85 contributors, removed 261 packages, updated 72 packages and audited 1149 packages in 324.101s
              42 packages are looking for funding
              found 1 low severity vulnerability
                run `npm audit fix` to fix them, or `npm audit` for details
              processing for module MMM-Carousel please wait
              npm WARN deprecated nodeunit@0.9.5: you are strongly encouraged to use other testing options
              npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
              npm WARN deprecated request@2.79.0: request has been deprecated, see https://github.com/request/request/issues/3142
              npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
              npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
              npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
              npm WARN deprecated har-validator@2.0.6: this library is no longer supported
              npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
              npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
              npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
              npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
              npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
              npm notice created a lockfile as package-lock.json. You should commit this file.
              added 522 packages from 374 contributors and audited 522 packages in 150.454s
              14 packages are looking for funding
              found 88 vulnerabilities (45 low, 12 moderate, 30 high, 1 critical)
              processing complete for module MMM-Carousel
              processing for module MMM-Remote-Control please wait
              added 31 packages from 26 contributors and audited 31 packages in 15.301s
              processing complete for module MMM-Remote-Control
              processing for module MMM-SoccerLiveScore please wait
              up to date in 1.338s
              processing complete for module MMM-SoccerLiveScore
              processing for module MMM-Formula1 please wait
              npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
              added 646 packages from 393 contributors and audited 646 packages in 176.234s
              58 packages are looking for funding
              found 2 low severity vulnerabilities
              processing complete for module MMM-Formula1
              processing for module MMM-ioBroker please wait
              npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
              added 47 packages from 502 contributors and audited 47 packages in 20.087s
              3 packages are looking for funding
              processing complete for module MMM-ioBroker
              processing for module MMM-Fuel please wait
              added 458 packages from 286 contributors and audited 458 packages in 137.315s
              84 packages are looking for funding
              processing complete for module MMM-Fuel
              processing for module MMM-PublicTransportHafas please wait
              npm WARN deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
              npm WARN deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
              added 33 packages from 23 contributors and audited 33 packages in 18.988s
              processing complete for module MMM-PublicTransportHafas
              processing for module MMM-Tools please wait
              added 3 packages from 3 contributors and audited 3 packages in 4.837s
              processing complete for module MMM-Tools
              processing for module MMM-Traffic please wait
              added 2 packages from 7 contributors and audited 2 packages in 5.081s
              processing complete for module MMM-Traffic
              restoring custom.css
              what sy me this? What must i do for them?
              Must i make really npm audit fix in the console??
                sdetweil @kusselin
                @kusselin ok, wait some more… it will say its done
                • kusselinK
                  kusselin
                  o.k. and this is my version now:
                  pi@raspberrypi:~/MagicMirror $ grep version package.json
                          "version": "2.14.0",
                    sdetweil @kusselin
                    @kusselin ok, then npm start
                    or pm2 start 0 if u use pm2
                    • kusselinK
                      kusselin
                      @sdetweil said in Display waste bins in color:
                      pm2 start 0
                      Heeey what should i say!!! Sam and ashistank…YOU ARE THE BEST!!! :-) :-)
                      After a reboot and npm2 start the colours are there!! :-)
                      pi@raspberrypi:~ $ pm2 start 0
                      [PM2] Applying action restartProcessId on app [0](ids: 0)
                      [PM2] [MagicMirror](0) ✓
                      [PM2] Process successfully started
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 1    │ online    │ 0%       │ 2.5mb    │
                      Thank You very much !!
                      • kusselinK
                        kusselin
                        Sam, it is possible that you can say me the colour for brown in config.js code…the name brown is not working you can see it at the picture
                          sdetweil @kusselin
                          @kusselin https://www.rapidtables.com/web/color/brown-color.html
                          • kusselinK
                            kusselin
                            Thanks…now it run fine
                            • 3 / 3
