    Display waste bins in color
    52 Posts 3 Posters 25.6k Views 3 Watching
    • kusselinK Offline
      kusselin
      @ashishtank said in Display waste bins in color:
      once new version of MM is released today, you will get all the latest code and then it should work.
      Ahh ok…since achuell is the latest version 2.13.0. i have this version…and today a new verdion is comming…ok i will wait…where can i find the info for new versuon?
      S A 2 Replies Last reply Reply Quote 0
        sdetweil @kusselin
        @kusselin it will be displayed in the banner above when released (version will be 2.14)
          ashishtank Module Developer @kusselin
          @kusselin details will be here https://forum.magicmirror.builders/category/17/magicmirror
          • kusselinK Offline
            kusselin
            Thank you
              sdetweil @kusselin
              @kusselin new release available
              • kusselinK Offline
                kusselin
                Ok i see…thanks snd now the update how is standing in the update manual here…right
                  sdetweil @kusselin
                  @kusselin eh? not sure what u said. run my upgrade script
                  see
                  • kusselinK Offline
                    kusselin
                    o.k thanks
                    • kusselinK Offline
                      kusselin
                      here my update installation:
                      pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                      No LSB modules are available.
                      doing test run = false
                      saving custom.css
                      upgrading from version 2.13.0 to 2.14.0
                      fetching latest revisions
                      From https://github.com/MichMich/MagicMirror
                         3dbe8bfb..10dc315f  master     -> origin/master
                       * [new tag]           V2.2.1     -> V2.2.1
                       * [new tag]           v.2.1.3    -> v.2.1.3
                       * [new tag]           v2.0.0     -> v2.0.0
                       * [new tag]           v2.0.1     -> v2.0.1
                       * [new tag]           v2.0.2     -> v2.0.2
                       * [new tag]           v2.0.3     -> v2.0.3
                       * [new tag]           v2.0.4     -> v2.0.4
                       * [new tag]           v2.0.5     -> v2.0.5
                       * [new tag]           v2.1.0     -> v2.1.0
                       * [new tag]           v2.1.1     -> v2.1.1
                       * [new tag]           v2.1.2     -> v2.1.2
                       * [new tag]           v2.10.0    -> v2.10.0
                       * [new tag]           v2.10.1    -> v2.10.1
                       * [new tag]           v2.11.0    -> v2.11.0
                       * [new tag]           v2.12.0    -> v2.12.0
                       * [new tag]           v2.14.0    -> v2.14.0
                       * [new tag]           v2.2.0     -> v2.2.0
                       * [new tag]           v2.2.2     -> v2.2.2
                       * [new tag]           v2.3.0     -> v2.3.0
                       * [new tag]           v2.3.1     -> v2.3.1
                       * [new tag]           v2.4.0     -> v2.4.0
                       * [new tag]           v2.4.1     -> v2.4.1
                       * [new tag]           v2.5.0     -> v2.5.0
                       * [new tag]           v2.6.0     -> v2.6.0
                       * [new tag]           v2.7.0     -> v2.7.0
                       * [new tag]           v2.7.1     -> v2.7.1
                       * [new tag]           v2.8.0     -> v2.8.0
                       * [new tag]           v2.9.0     -> v2.9.0
                      > core-js@3.7.0 postinstall /home/pi/MagicMirror/node_modules/core-js
                      > node -e "try{require('./postinstall')}catch(e){}"
                      Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                      The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                      > https://opencollective.com/core-js
                      > https://www.patreon.com/zloirock
                      Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                      > electron@8.5.3 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      > magicmirror@2.14.0 install /home/pi/MagicMirror
                      " && cd vendor && npm install --loglevel=error
                      > @fortawesome/fontawesome-free@5.15.1 postinstall /home/pi/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free
                      > node attribution.js
                      Font Awesome Free 5.15.1 by @fontawesome - https://fontawesome.com
                      License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License)
                      updated 3 packages and audited 24 packages in 18.623s
                      1 package is looking for funding
                        run `npm fund` for details
                      found 0 vulnerabilities
                      > magicmirror@2.14.0 postinstall /home/pi/MagicMirror
                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                      > magicmirror@2.14.0 install-fonts /home/pi/MagicMirror
                      > echo "Installing fonts ...
                      " && cd fonts && npm install --loglevel=error
                      audited 1 package in 3.134s
                      added 55 packages from 85 contributors, removed 261 packages, updated 72 packages and audited 1149 packages in 324.101s
                      42 packages are looking for funding
                      found 1 low severity vulnerability
                        run `npm audit fix` to fix them, or `npm audit` for details
                      processing for module MMM-Carousel please wait
                      npm WARN deprecated nodeunit@0.9.5: you are strongly encouraged to use other testing options
                      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                      npm WARN deprecated request@2.79.0: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                      npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                      npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
                      npm WARN deprecated har-validator@2.0.6: this library is no longer supported
                      npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                      npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                      npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
                      npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
                      npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      added 522 packages from 374 contributors and audited 522 packages in 150.454s
                      14 packages are looking for funding
                      found 88 vulnerabilities (45 low, 12 moderate, 30 high, 1 critical)
                      processing complete for module MMM-Carousel
                      processing for module MMM-Remote-Control please wait
                      added 31 packages from 26 contributors and audited 31 packages in 15.301s
                      processing complete for module MMM-Remote-Control
                      processing for module MMM-SoccerLiveScore please wait
                      up to date in 1.338s
                      processing complete for module MMM-SoccerLiveScore
                      processing for module MMM-Formula1 please wait
                      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                      added 646 packages from 393 contributors and audited 646 packages in 176.234s
                      58 packages are looking for funding
                      found 2 low severity vulnerabilities
                      processing complete for module MMM-Formula1
                      processing for module MMM-ioBroker please wait
                      npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                      added 47 packages from 502 contributors and audited 47 packages in 20.087s
                      3 packages are looking for funding
                      processing complete for module MMM-ioBroker
                      processing for module MMM-Fuel please wait
                      added 458 packages from 286 contributors and audited 458 packages in 137.315s
                      84 packages are looking for funding
                      processing complete for module MMM-Fuel
                      processing for module MMM-PublicTransportHafas please wait
                      npm WARN deprecated hafas-client@2.10.4: Deprecated. Use hafas-client@latest.
                      npm WARN deprecated vbb-translate-ids@3.1.0: Deprecated. Use vbb-translate-ids@latest.
                      added 33 packages from 23 contributors and audited 33 packages in 18.988s
                      processing complete for module MMM-PublicTransportHafas
                      processing for module MMM-Tools please wait
                      added 3 packages from 3 contributors and audited 3 packages in 4.837s
                      processing complete for module MMM-Tools
                      processing for module MMM-Traffic please wait
                      added 2 packages from 7 contributors and audited 2 packages in 5.081s
                      processing complete for module MMM-Traffic
                      restoring custom.css
                      what sy me this? What must i do for them?
                      Must i make really npm audit fix in the console??
                        sdetweil @kusselin
                        @kusselin ok, wait some more… it will say its done
                        • kusselinK Offline
                          kusselin
                          o.k. and this is my version now:
                          pi@raspberrypi:~/MagicMirror $ grep version package.json
                                  "version": "2.14.0",
                            sdetweil @kusselin
                            @kusselin ok, then npm start
                            or pm2 start 0 if u use pm2
                            • kusselinK Offline
                              kusselin
                              @sdetweil said in Display waste bins in color:
                              pm2 start 0
                              Heeey what should i say!!! Sam and ashistank…YOU ARE THE BEST!!! :-) :-)
                              After a reboot and npm2 start the colours are there!! :-)
                              pi@raspberrypi:~ $ pm2 start 0
                              [PM2] Applying action restartProcessId on app [0](ids: 0)
                              [PM2] [MagicMirror](0) ✓
                              [PM2] Process successfully started
                              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                              │ 0  │ MagicMirror        │ fork     │ 1    │ online    │ 0%       │ 2.5mb    │
                              Thank You very much !!
                              • kusselinK Offline
                                kusselin
                                Sam, it is possible that you can say me the colour for brown in config.js code…the name brown is not working you can see it at the picture
                                  sdetweil @kusselin
                                  @kusselin https://www.rapidtables.com/web/color/brown-color.html
                                  • kusselinK Offline
                                    kusselin
                                    Thanks…now it run fine
                                    • 3 / 3
