    🎂🥂Emoji support
    4 Posts 3 Posters 7.0k Views 2 Watching
      MikeBishop
      Running on a Raspberry Pi 4, and one of my calendar feeds has emoji in the event names. When accessing the MM with a browser, they display fine; on the screen connected to the Pi, however, they’re just little squares.
      I know this is more likely an electron, Node, or XWindows issue than MM itself, but has anyone found a solution for getting emoji to render properly?
        A Former User
        Have you tried to write the emojis in HTML Codes?
        For your cake emoji it would be: 🎂
        & #127874;
        remove the spaces between the & and #
        Hope this helps!
          MikeBishop
          That renders as the text, for some reason. However, the cake shows up properly after apt install fonts-noto-color-emoji and a reboot.
            phil
            I could not install the package above on my pi installation: package not found
            But sudo apt install fonts-symbola worked. I just needed to restart the magicmirror service. Although, the emojis are not colored. But still better than the square ;-)
